It is currently Fri May 25, 2012 6:49 pm
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 2 posts ]
 Post subject: Thistle Tough Coat
PostPosted: Tue Sep 27, 2011 12:50 pm
Been thanked: 26 times
Ive got a room todo for a friend which has two walls which are breeze block at present.
Ive seen tough coat empty bags on site before, but never seen it applied.
I was tempted to use it as the finish seemed good. How is it usually applied? Is it like a one coast S+C render? Where you trowel it on, flatten it out, then devil float it once its going firm?
My project blog - Check it out
 Post subject: Re: Thistle Tough Coat
PostPosted: Sat Oct 08, 2011 9:21 am
Has thanked: 44 times
Been thanked: 114 times
yeh.. basically, its better than hardwall on lightweight blocks... still might need a bit of gyprime first though.... excessive wetting of the blocks prior to application may cause the blocks to crack cos theyll just drink it...
http://www.british-gypsum.com/pdf/DS-10 ... 20Coat.pdf
Users browsing this forum: No registered users and 16 guests
