It is currently Sat Mar 24, 2018 2:02 pm
Visit Thermo worx
 Post subject: Thermo Value Stuck
PostPosted: Sun Sep 10, 2017 8:47 pm
Has thanked: 36 times
Its that time of year again where the central heating must go on!
Bleed all radiators and as usual some radiators did not come on, got 1 out of 3 that did not come on by using the old trick of removing the valve handle and with pliers moving in and out the pin.
However this did not work for 2 radiators; if I leave the pin just a bit in they heat up, but even with oil they are stiff and fail to come on; i.e. when i fit the valve handle it pushes the pin in and off it goes!
So my question is what do I need to replace, they are over 25 years old.
I am not a plumber but can drain the system and refill, just do not want to do any pipe work as in bedrooms!
See photo of valve.
Many thanks,
 Post subject: Re: Thermo Value Stuck
PostPosted: Mon Sep 11, 2017 11:07 am
Has thanked: 95 times
Been thanked: 291 times
I am not the expert and hope one will join and advise, but it looks like you have a 1/2 union tail in the rad and unless you are willing (easy job usually, if you have the 1/2 hex allen key tool and the ptfe looks recent with no rust showing on rad boss) to replace the tail with a 15mm compression type, then you need to source original TRV type 15mm x 1/2"" but better take old one to a Plumbing Centre to match up.
Flow direction is important or a bi-directional trv.
If by chance it is older style and hence bigger with 3/4" union, then this is a sample:-
For this message the author aeromech3 has received gratitude : graham101
Users browsing this forum: D Hailsham and 1 guest
