Ultimate Handyman Home
tensol 70
Post new topic   Reply to topic   Thank Post    www.ultimatehandyman.co.uk Forum Index -> General DIY forum -> Acrylic Forum
martek man
Junior Member
PostPosted: Sun Sep 09, 2007 3:56 pm    Post subject: tensol 70 Add User to Ignore List Reply with quote
Hi
As anyone any advice on mixing Tensol 70, there is 2 parts, resin & hardener but i`m unable to find any instructions regarding quantity to use Bang Head
Back to top
PostPosted: Sun Sep 09, 2007 4:05 pm    Post subject: Add User to Ignore List Reply with quote
It comes in two containers that are the correct quantity for one mix and so you mix the whole contents of both together and this will give you the correct ratio. But you then have to use the full amount or else it will harden!
From the size of the containers that you have you can work out how much to mix if you do not want to use it all at once.
So for example if one container contains 500ml and the other one 100ml then you could mix 100ml from the first container with 20ml from the second container etc.
DIY | DIY Video
Back to top
Display posts from previous:
Post new topic   Reply to topic    Thank Post    www.ultimatehandyman.co.uk Forum Index -> General DIY forum -> Acrylic Forum All times are GMT
Page 1 of 1
