Ultimate Handyman Home
Teng Socket set
Post new topic   This topic is locked: you cannot edit posts or make replies.   Thank Post    www.ultimatehandyman.co.uk Forum Index -> Hand tool reviews
PostPosted: Sun May 18, 2008 12:31 pm    Post subject: Teng Socket set Add User to Ignore List Reply with quote
1/2 inch drive teng socket set. Teng MR3839
I recently purchased this Teng socket set in order to do a few jobs, which I would not normally do. The quality of manufacture is excellent as is to be expected with all teng tools.
The ratchet has plenty of teeth which means that it is good in confined spaces.
The sockets have a matt finish, which seems durable.
The kit contains-
39 piece 3/8" drive socket set containing regular and deep metric 6 point sockets, coupler adaptor, ½"-3/8" adapator, 3" wobble extension bar and 6" extension, universal joint, 2 spark plug sockets 16 and 21 mm, fibre reinforced reversible ratchet as well as 11 bits.
Supplied in plastic case with click lock and folding handle. The underside of the case is fitted with rubber feet to prevent it from sliding.
MR3839 39 piece 3/8" drive Regular/Deep Metric Base Set
(350x180x55mm, 2.4 kilos)
Accessories 3/8" drive
FRP ratchet
universal joint
3"wobble extension
6" extension bar
coupler adaptor
1/2 T-bar adaptor
Regular sockets 3/8" drive 6 point 8, 9, 10, 11, 12, 13, 14, 15, 16, 17,
18, 19, 21,22mm
Deep sockets 3/8" drive 6 point 8, 10, 12, 13, 17, 19mm
Spark plug sockets 3/8" drive 6 point 16 & 21mm
Bits 1/4" hex TX10, TX15, TX20, 5mm hex,
6mm hex, PH1, PH2, PZ1, PZ2,
4mm flat, 5.5mm flat
One particular thing that I do like about the ratchet is that once an attachment is fixed on to it you have to press the release button for it to be released and so there is little chance of becoming detached accidentally.
This is an excellent piece of kit and you can relax knowing that it has a lifetime guarantee Thumbright
DIY | DIY Video
Back to top
Hitch
PostPosted: Sun May 18, 2008 7:09 pm    Post subject: Add User to Ignore List Reply with quote
Thats the same as the one i won in the competiton ages ago by the looks of it.
Very usefull little set. The 3/8"-1/2" adaptor can be use with the extension to make a tommy bar, and use that one side, the ratchet the other.
Thumbright
Back to top
PostPosted: Sun May 18, 2008 7:15 pm    Post subject: Add User to Ignore List Reply with quote
I'm impressed with mine, it is a great piece of kit and will get some use Wink
DIY | DIY Video
Back to top
chippymike
PostPosted: Sun May 18, 2008 8:49 pm    Post subject: Add User to Ignore List Reply with quote
i have a few teng sockets and they are very well made
Back to top
View user's profile Send private message MSN Messenger
bobdabuilda
Junior Member
PostPosted: Fri May 30, 2008 10:31 pm    Post subject: Add User to Ignore List Reply with quote
Are the Teng as good as the Sealey pro range? Can't decide between the two...
Back to top
PostPosted: Fri May 30, 2008 10:34 pm    Post subject: Add User to Ignore List Reply with quote
They are good and have a lifetime guarantee.
Do the sealy pro range ones have a lifetime guarantee?
If so then get the one that you feel most comfortable with Wink
DIY | DIY Video
Back to top
Display posts from previous:
Post new topic   This topic is locked: you cannot edit posts or make replies.    Thank Post    www.ultimatehandyman.co.uk Forum Index -> Hand tool reviews All times are GMT
Page 1 of 1
