Page 1 of 1
[ 10 posts ] |
| Author |
Message |
Dickie
Posted: Wed Jun 08, 2011 3:22 pm |
| Senior Member |
Joined: Fri Mar 11, 2011 10:55 am Posts: 1022 Location: Glasgow Has thanked: 56 times Been thanked: 79 times
I'm going to tape & fill a few plasterboard joints. I was thinking of using scrim adhesive tape and not paper, anyone got views on this stuff? Also I read somewhere that some joint fillers are better than others with scrim tape, again anyone got any views? There's only about 18m2 of plasterboard to tape & fill, so quite a small area, so what's the best joint filler, pre-mix or bags? Thanks for reading.
_________________ Time-served Plumber/Heating Engineer & general wind-up merchant. The Plumbers AnthemIf you have found my help or tips useful please donate here. Thank You; donnas-dream-house-charity-t52110.htmlGas Safe RGI Scottish, British & Proud.
| Top |
jozeffo
Posted: Wed Jun 08, 2011 3:48 pm |
| Senior Member |
Joined: Tue Dec 02, 2008 7:52 pm Posts: 2448 Location: South London Has thanked: 58 times Been thanked: 272 times
Premixed filler is more convenient and for that reason, I use it all the time. I would also use the scrim tape, not the paper.
Step 1, put the tape in Step 2 go over with the filler, taking off all the excess and making sure the tape doesnt ruck. Step 3 Go over again about three hours later when the first lot has gone hard. A little less pressure Step 4 When it is dry, sand it lightly to remove any nibs or protrusion and apply another thin coat, feathering it out past the edges of the joint. Step 5 when bone dry, sand with a pole sander, not just a piece of sandpaper.
Step 2 beds the tape and fills up most of the recess created by the tapered edges of the boards. Step 3 fills and holes left after step 2 and makes up for any shrinkage. Step 4 makes it very slightly proud of the board and step 5 gives a perfect finish.
Some experts can do it in less steps and still achieve a perfect finish, some use a sponge to feather to save time, but the method I have given can be done by and fool, myself included.
For this message the author jozeffo has received gratitude : Dickie |
| Top |
register or
log in
evile
Posted: Wed Jun 08, 2011 4:43 pm |
| Plasterer |
Joined: Sun Aug 24, 2008 8:35 pm Posts: 462 Location: Birmingham Has thanked: 8 times Been thanked: 28 times
I would do it as above to but just in a couple of passes (probably due to the amount of times I've done it tho)
And I would use BGypsum Easi-fill, I find this to be the best filler out there but it is a little on the expensive side and to be honest by the sound of it you just won’t need half of even a small bag so I do completely agree with jozeffo, a pre mix would be best for you
For this message the author evile has received gratitude : Dickie |
| Top |
register or
log in
Dickie
Posted: Wed Jun 08, 2011 5:13 pm |
| Senior Member |
Thanks very much chaps, great advice.
| Top |
register or
log in
Dickie
Posted: Thu Jun 09, 2011 8:30 am |
| Senior Member |
Sorry, but do you have any further tips for internal corners & ceilings? Loads of videos on this subject on Youtube, but lots of conflicting views, I guess everyone has their own way.
| Top |
register or
log in
jozeffo
Posted: Thu Jun 09, 2011 9:16 am |
| Senior Member |
| Top |
register or
log in
register or
log in
register or
log in
register or
log in
Dickie
Posted: Tue Jun 21, 2011 10:12 am |
| Senior Member |
£5.94 & free delivery, it's stainless steel & is the dogs danglers!! Thanks mate.
| Top |
register or
log in
Page 1 of 1
[ 10 posts ] |
