It is currently Fri Feb 22, 2019 2:26 pm
Post new topic Reply to topic  [ 17 posts ]  Go to page 1, 2  Next
PostPosted: Sun Mar 11, 2018 10:12 am
Can I change a t8 fitting to t5?
They used to have fluorescent tubes but I will be using t5 led tubes... Would this work?
Http://www.****.com/tridonic-switch-start-choke-ec-2x18-oc502k
This is the ballast I have.
I don't wish to purchase new ones if I can avoid it.
Sent from my SM-A520F using Tapatalk
PostPosted: Sun Mar 11, 2018 10:23 am
Has thanked: 40 times
Been thanked: 1429 times
Couple of things.
The website you link to is banned on this forum (They probably posted spam) so its not possible to follow your link.
Some, not all LED replacement fluorescent tubes do NOT need a ballast.
Bearing in mind the above, I would suggest you ask the supplier of your LED "tubes"
Or, change the light fittings to say GU10 and use single LED lamps, it may cost a bit more initially, but lamps are cheaper.
PostPosted: Sun Mar 11, 2018 10:29 am
someone-else wrote:
Couple of things.
Ah okay, I will look into them! And I see link not working but you can see the model at the end of the remaining link :)
Chris
PostPosted: Sun Mar 11, 2018 11:00 am
Approved Electrician
Has thanked: 168 times
Been thanked: 585 times
someone-else wrote:
Couple of things.
WTF have GU10's got to do with it :scratch: ?
The OP has fluorescent strip lights.
PostPosted: Sun Mar 11, 2018 11:04 am
OnlyMe wrote:
someone-else wrote:
Couple of things.
Correct and GU10 are spots?
PostPosted: Sun Mar 11, 2018 11:05 am
I know he has fluorescent tubes. I merely suggested "change the light fittings to say GU10 and use single LED lamps"
My thinking is it will cost less in the long run to have GU10's than LED fluorescents, but I have since looked at the cost and they cost considerably less than I thought.
PostPosted: Sun Mar 11, 2018 11:09 am
Http://www.****.com/tridonic-switch-sta ... x18-oc502k
T8 and T5 tubes have different pin fittings so you cannot swap one for the other.
Led tubes do not need a ballast.
PostPosted: Sun Mar 11, 2018 11:13 am
Ahh, so you are suggesting a bar spot light that uses GU10s?
PostPosted: Sun Mar 11, 2018 11:14 am
I'm aware they are different sizes, however I currently am using a ballast for led tubes so if I get the same ones then I was under the impression they also need a ballast. I will look in to the strip and see what manufacturers say.
Many thanks for your advice
PostPosted: Sun Mar 11, 2018 1:14 pm
Now that is what I would have said, BUT, a quick use of google...........
QUESTION:
Do I need to replace or rewire my fluorescent fixture in order to have the benefits of LED Technology?
ANSWER:
No, as far back as 2004, design engineers at LED****** began developing an advanced patent-pending driver technology to allow LED tube lights to be compatible with virtually all standard fluorescent ballasts.
ANOTHER WEBSITE:
No, removing the ballast does not make your LED conversion consume less electricity. The ballast is an essential component which converts and regulates power delivered to a fluorescent tube. LEDs also require this power conversion and regulation; it can not be avoided. While it is true that the ballast is not 100% efficient (nothing is), the LED Tube Lights which require removing the ballast have, simply put, a ballast inside the tube itself. As a result, those products suffer from the exact same inefficiencies as the existing ballast.
As I said, I would agree with you, (I have to admit, i have never changed one) but alot of places say the same thing in respect of a ballast.
Yes.
PostPosted: Sun Mar 11, 2018 1:18 pm
QUESTION:
ANSWER:
ANOTHER WEBSITE:
Yes.
Okay since my current led tubes do use a ballast, would I be able to convert the plugs from t8 to t5 without and adverse effects?
PostPosted: Sun Mar 11, 2018 2:12 pm
QUESTION:
ANSWER:
ANOTHER WEBSITE:
Remember that Google can lead you to sites that have incorrect information.
The facts are that LED tubes do not need ballasts. It may be possible to run a LED tube through a ballast (but almost certainly not an electronic one) if you swap the starter for a short circuit.
PostPosted: Sun Mar 11, 2018 2:25 pm
Your LED tubes are NOT using a ballast. They are merely fed through an existing ballast from when the fitting had fluorescent tubes. The ballast sits there doing nothing (other than wasting a bit of energy).
PostPosted: Sun Mar 11, 2018 2:29 pm
I see... So how would I wire directly to a plug without a ballast?
PostPosted: Sun Mar 11, 2018 2:40 pm
Now that depends on the tubes.
I just need a bit more info. Did the first lot of LED tubes come with a replacement starter switch?
