It is currently Wed Feb 20, 2019 1:41 am
Post new topic Reply to topic  [ 16 posts ]  Go to page 1, 2  Next
 Post subject: switches in kitchen
PostPosted: Wed Oct 04, 2017 5:50 pm
Hi all,
I have some switches (similar looking to light switches) which i want to change to brushed steel. Ive looked at the inside and can see they are similar to a cooker switch in that they have a feed and a mains.
My question is what are these type of switches called ?
Cheers ,
 Post subject: Re: switches in kitchen
PostPosted: Wed Oct 04, 2017 6:13 pm
Been thanked: 3 times
kevg4871 wrote:
Hi all,
Cheers ,
Double pole switch some with neon indicator some not
Sent from my SM-G930F using Tapatalk
PostPosted: Wed Oct 04, 2017 6:23 pm
thanks, should these be fused ?
PostPosted: Wed Oct 04, 2017 6:29 pm
Depends on set up some are some not
PostPosted: Wed Oct 04, 2017 6:38 pm
Has thanked: 1531 times
Been thanked: 3852 times
Maybe. If you have a fixed installation such as a built in dishwasher then you will or may require a Switched Fused Connection unit
These are generally easy to identify by a "slot" which holds a standard 3/5/13 Amp fuse. If you already have above counter SFCU's then replace like for like.
PostPosted: Wed Oct 04, 2017 7:22 pm
thanks for that. These switches have been installed for dishwasher, washing machine, fridge and freezer.
I will look into double pole switches.
PostPosted: Wed Oct 04, 2017 7:57 pm
Switched fused units if that is what you already have... :roll:
PostPosted: Wed Oct 04, 2017 9:14 pm
Has thanked: 40 times
Been thanked: 1429 times
Picture would help.
They may just be isolation switches
And they Don't have to be FCU's. Some times there is an isolation switch above the work top, and a socket below, so the fuse is in the plug of the appliance.
Perhaps one of
Is what you are looking for?
This one is from Here (First one I found)
PostPosted: Wed Oct 04, 2017 9:18 pm
That looks more like it. I guess they are wired mains and feed?
Cheers
PostPosted: Wed Oct 04, 2017 9:57 pm
Sorry, I do not know what you mean. They are double pole 20A switches.
PostPosted: Wed Oct 04, 2017 11:38 pm
So what you describe as being isolation switches above worktop then that is what I have. I was wondering how to wire them? Current wiring is a mains in and feed out to appkiance.
PostPosted: Thu Oct 05, 2017 5:21 am
The ones pictured will be the same as what you have. Strait swap. :-) (But turn the mains off at the consumers unit First)
For this message the author someone-else has received thanks - 2: james232, multiman
PostPosted: Thu Oct 05, 2017 7:09 pm
Approved Electrician
Has thanked: 168 times
Been thanked: 585 times
There is a good reason for using the double pole 20A switches over the switched fused spurs. I do a lot of work for landlords and a certain council and I nearly always fit DP switches.
Assuming, as you said, they are powering a single socket, then if there is a fault with the appliance, the fuse blows and the tenant calls to say "my washing machine is not working". With a DP switch you can get the tenant to plug something else into the socket to see if the socket works. With a switched FCU the fuse in the there may also have blown (or indeed blown leaving the appliance fuse working) and so the socket will not work with the test appliance. It saves the landlord having to rush about checking his electrics.
For this message the author OnlyMe has received gratitude : Morbius
PostPosted: Sat Oct 07, 2017 4:27 pm
Has thanked: 65 times
Been thanked: 552 times
It would seem your talking about a grid switch, these have a plate which the switches fit into and also if required fuses, cable brushes, TV sockets, LAN sockets, and 13 amp sockets, you make them up to suit what you want, some actually come ready engraved freezer etc. Some have a grid which is covered with a face plate, and some the face plate is the grid, often wires as a ring circuit and once installed really do need testing as often very tight and easy to have a wire become disconnected to test often you need to go inside the consumer unit which in turn may have live exposed terminals which clearly need to be treated with extreme caution.
What you need to consider before you start is are you happy doing the inspection and testing? If not then get an electrician.
PostPosted: Sun Oct 08, 2017 9:55 am
Good God he is only wanting to swap a few switches!
