It is currently Sun Apr 21, 2019 5:31 pm
 Post subject: SWA cable to workshop
PostPosted: Mon Oct 17, 2005 2:13 pm
Hi Folks,
I'm going to be wiring up my workshop soon but I'm a little uncertain about what size armoured cable to run to it.
There shouldn't be anything other than the usual power tools being used and mostly only one of them at a time. I was going for 2 32A MCB ring circuits and a lighting circuit
The distance from the house to the workshop is about 20 metres. Is there a formula for working out the thickness of cable?
 Post subject:
PostPosted: Mon Oct 17, 2005 4:56 pm
Has thanked: 1407 times
Been thanked: 1250 times
Hi Chris,
Welcome to the forum!
I am not a qualified electrician and I am unable to give specific electrical advice as to which is the correct thickness of cable to use.
I always air on the side of caution and use a thicker wire than is necessary, for example I recently wired a shower (before part P) and the guy in the shop said that I could use 6mm Twin core and earth, I chose to use 10mm twin core and earth as it makes it a lot easier, should I wish to upgrade the shower in the future.
There is a formula that can work out the thickness of the cable to be used and this will involve diversification.
There is a cable size selection calculator on the TLC direct site-
http://www.tlc-direct.co.uk/Technical/Charts/VoltageDrop.html
This is for guidance only but will give you a rough Idea, I have just tried the calculator for 5kw, which recommends 2.5mm and I also tried 10kw which recommended 6mm wire. I would say that 5kw would be a more realistic figure unless you are using some major power tools.
I would recommend getting the cable from a dedicated electrical shop and get the advice from the guys in the shop as these are normally qualified electricians themselves.
Hope this helps a little!
Check out our nominated charity
 Post subject:
PostPosted: Tue Oct 18, 2005 10:58 am
Thanks. I'll give it a try :D
