It is currently Fri May 25, 2012 6:03 pm
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 7 posts ]
 Post subject: Suction towel rail
PostPosted: Thu May 12, 2011 10:04 pm
Has thanked: 21 times
Hi
I have had the bathroom tilled recently. I need to fit a towel rail etc.
I am very reluctant drill newly finished tiles. :?
Most DIY shops sell suction towel rail / toilet roll holder. Are they any good? do they stay on the wall or fall down and do more damage than good :cb
Any advice would be helpful
 Post subject: Re: Suction towel rail
PostPosted: Fri May 13, 2011 12:47 am
Has thanked: 31 times
Been thanked: 35 times
I was woken by an almighty crash earlier this year and assumed the house was being burgled. It turned out to be the bathroom 'hold all' basket that held the shower gel, etc. Yes, you guessed, it was attached with suction pads. They're a load of bo++ocks in my opinion. They rely on atmospheric pressure to hold the cups against the tile, each applying 14.7 psig. Trouble is, the suckers will always have a certain leak rate and when the pressure can no longer support the weight it will do what Newton said it would do. Fall. I don't trust them now. Best to have good old plugs and screws in my opinion. With a good drill bit there is no problem drilling tiles....just turn the hammer action off!
http://www.isistherapytraining.com/
For this message the author southwood3 has received gratitude : newdud
PostPosted: Fri May 13, 2011 1:33 am
Has thanked: 134 times
Been thanked: 473 times
use a masonery bit hammer off with several layers off masking tape
high speed then once through the tile if nowt seems to happen go on to hammer action
For this message the author big-all has received gratitude : newdud
PostPosted: Fri May 13, 2011 9:50 am
Has thanked: 160 times
Been thanked: 81 times
I am a newbie at diy and tiling but we had to drill into ours. I used plenty of masking tape and some tile drills from screwfix and it went ok.
Good luck :thumbright:
Nick
If UHM's helped then please check out UHM's Nominated charity - http://www.donnasdreamhouse.co.uk/
PostPosted: Fri May 13, 2011 10:21 am
Been thanked: 19 times
As above. Except if they are porcelain tiles you'll be better off with a 6mm diamond core bit.
PostPosted: Fri May 13, 2011 10:43 am
Has thanked: 16 times
Been thanked: 339 times
6-piece-glass-drill-bit-set-t42942.html
I know it is nearly a month ago but I was in Aldi in Blackpool yesterday and they still had some, so may be worth a trip to your local Aldi if nearby and see if they have any left.
dave
But you cannot tell him much.
PostPosted: Fri May 13, 2011 2:09 pm
I used ones similar to the ones that Dave has shown above :thumbright:
Nick
