It is currently Sun Aug 19, 2018 5:06 pm
PostPosted: Mon Oct 16, 2017 3:32 pm
Has thanked: 4 times
Hey guys, so I've just put up a 6ft x 8ft shed. I want to hang a couple of mountain bikes from the rear wall (opposite the door) of the shed, and also be able to hang some lightweight tools from the shed walls so I can tidy up the space a little.
So the obvious way to do this I guess it to cover the inside of the shed walls with some sort of sheet timber - but I don't know which type would suit the job best. MDF? Chipboard? Plywood? If so, what width?
Any help would be greatly appreciated!
Ant
PostPosted: Mon Oct 16, 2017 3:40 pm
Has thanked: 44 times
Been thanked: 1303 times
None of the above.
Go and buy a solid plank of wood (floor board) cut it to width and fix that to all "joists" (For want of a better word) then hang stuff from that.
PostPosted: Mon Oct 16, 2017 3:54 pm
Has thanked: 1106 times
Been thanked: 1026 times
Agreed, apart from using "floor board" which might well end up with tongue and grooved boards which you don't need. I'd go a bit heavier thickness for hanging bikes off as well.
Something like
http://www.builderdepot.co.uk/par-softw ... metre.html
PostPosted: Mon Oct 16, 2017 4:08 pm
Has thanked: 680 times
Been thanked: 1938 times
i personally would go for 12mm exteriour ply on at least 2 walls in an "L" shape configuration this will avoid the weight trying to pull the shed out off shape
you could maybe cut one sheet into a 8x2ft and a 6x2ft section
For this message the author big-all has received gratitude : bishylewis
PostPosted: Mon Oct 16, 2017 4:27 pm
Has thanked: 399 times
Been thanked: 1433 times
big-all wrote:
I personally would go for 12mm exterior ply on at least 2 walls in an "L" shape configuration this will avoid the weight trying to pull the shed out off shape
:withstupid:
Hampshire Open Studios - 18th - 27 August 2018
http://www.hampshireopenstudios.org.uk/
Come and see me and/or my friends and our work at venue 62.
http://www.hampshireopenstudios.org.uk/ ... ty-friends
PostPosted: Tue Oct 24, 2017 11:35 am
Has thanked: 43 times
Been thanked: 3 times
BikeRadar has this article about shed security. It doesn't cover strengthening shed walls, but has some useful extra tips.
As well as strengthening the shed itself, how about a shed shackle for bikes?
Also, have a look at security locking bars for sheds. There's a few versions of these available.
PostPosted: Tue Oct 24, 2017 11:56 am
Has thanked: 16 times
Been thanked: 93 times
I have used CLS timber on my shed to brace it better,
quite cheap to buy.
PostPosted: Tue Oct 24, 2017 1:40 pm
the idea for 12mm ply is its strong enough to hang most things off without further support
and in the odd areas where further strength may be required you can install 2x1 or 3x2" behind before installation or in front afterwards
