It is currently Fri May 25, 2012 5:50 pm
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 23 posts ]  Go to page 1, 2  Next
PostPosted: Fri Dec 23, 2011 2:18 pm
Has thanked: 2 times
Hello, I'm 20 years old and I have been on a building maintenance apprenticeship for 6 months now and i absolutely love my job. I am at college doing 10 days training of every trade (i have finished masonry and plumbing so far). So, I have started to collect my own tools. Firstly the only proper tool i have is a makita 18v combi drill. My other tools are cheap ones from pound shop. All in one screwdriver and allen keys ect.
I'm slowly going to build up my tools and get the best of everything without filling my whole garage with tools i want to keep my tools as condensed as possible. So i was thinking instead of having 2 sets of screwdrivers. one set for electrical work and one set for all other. Should i just buy a really nice pair of electrical screwdriver set and would i be able to use them for everything? are they realiable? can they take a beating? or is it actually worth buying 2 sets?
Erm... also thought is it worth just buying adjustable spanners instead of a set?
Any tips for me while collecting?
Thanks for your time all comments will be appreciated. Thanks
PostPosted: Fri Dec 23, 2011 2:24 pm
Also. Any brand names to stay away from?
Which brand names never let you down?
PostPosted: Fri Dec 23, 2011 3:01 pm
Has thanked: 134 times
Been thanked: 473 times
i personally would avoid kits for specific jobs whilst you are setting up there is so much overlap that you will finish up with 3 times more kit than you need
do you have a van or transport or carry system in mind ??
PostPosted: Fri Dec 23, 2011 3:07 pm
no transport yet. I will do soon at about Febuary time.
PostPosted: Fri Dec 23, 2011 3:13 pm
car or van or other :dunno:
PostPosted: Fri Dec 23, 2011 3:14 pm
its going to be my first car mate
PostPosted: Fri Dec 23, 2011 3:45 pm
get your self a tool bag basics hammer 1 or2 wood chisels pozi1x2 screwdriver philips ph 1and2 a medium and small flat driver
you can use driver bits but would always carry a pz2 and a medium and small flat screwdriver
3 adjustable spanners will cover most situations excluding plumbing
worth getting a box off assorted screws from someone like me it contains around 400 assorted screws all sorts all sizes and lengths purely decided by what was on the floor when i filter the sawdust you also get the odd nail and machine bolt/nut and washer
i also have a tin with 2 or 4 or a handfull off ever thing like angle brackets wall fixings kitchen hinges machine bolts rulers joining blocks mending plates long screws nails string chalk electrical tap jigsaw blades stanley knife red/brown/yellow plugs and lots lots more
basically it a "saves you thinking tin" but remember to top up :thumbleft:
For this message the author big-all has received gratitude : lukelukeluke123
PostPosted: Fri Dec 23, 2011 4:26 pm
Has thanked: 14 times
Been thanked: 135 times
i would get a decent set of screwdrivers like the stanley fatmax range then add afew electrical drivers to it. i cant imagine you need more than a few slotteds and a pozi for elec?…
a set of whia allen keys, that will cover most sizes
for spanners i carry a 8mm and 10mm combi and a 12mm and 13mm combi then an adjustable and a set of waterpump pliers,
may as well just get elec rated pliers/snips
a decent claw hammer/ lump hammer/bolster chisel/crowbar
combination square
stanley knife
PostPosted: Sat Dec 24, 2011 10:45 am
Been thanked: 69 times
Adjustable spanners do NOT replace a set of proper spanners, only compliment them.
Mike
PostPosted: Sat Dec 24, 2011 12:27 pm
whilst i fully agree when starting up in work when money is short every spend must count to the maximum with the luxury off the correct tool for every job comes with time experience and finacial viability
PostPosted: Sat Dec 24, 2011 4:51 pm
was looking at a set of wera screwdrivers diamond tip for £25 of ebay. These any good?
PostPosted: Sat Dec 24, 2011 5:49 pm
Has thanked: 127 times
Been thanked: 392 times
Yes, Wera are normally a very good make :thumbright:
DIY | Donnas dream house
PostPosted: Sat Dec 24, 2011 6:25 pm
Has thanked: 76 times
Been thanked: 373 times
If you're doing building maintenance adjustables will be just fine as long as they're decent quality like Bahco or Rothy.
If you're working on plumbing one of these from toolstation is what you need split ring compression fitting spanner:
£7.49 - absolute bargain :wink:
PostPosted: Sat Dec 24, 2011 9:09 pm
Has thanked: 21 times
Been thanked: 58 times
Have you looked in the bargain tool section of this forum,there are some good deals to be had at the moment
bargain-tools-f27.html
http://www.donnasdreamhouse.co.uk/#/please-donate/4529684719
PostPosted: Wed Dec 28, 2011 8:46 pm
Has thanked: 31 times
Been thanked: 8 times
get yourself a decent saw mate aswell, just stay away from no-name tools or cheapo own brand tools
buy cheap buy twice
