It is currently Fri May 25, 2012 5:47 pm
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 14 posts ]
PostPosted: Sun Dec 14, 2008 6:36 pm
On attempting a start up, I end up with a blue background with the following message.
STOP: c0000218 {Registry File Failure}
the registry cannot load the hive (file):
SystemRoot\System32\Config\SOFTWARE
or its log or alternate.
it is corrupt, absent, or not writable.
beginning dump of physical memory
physical memory dump complete.
contact your system administrator or technical support group for
further assistance.
I get this message every time I attempt a start up. It only started happening after I uninstalled some programmes.
I have a Dell Dimension 3100 with Windows XP and I dont recall getting any restore disks with the system. Any help greatly appreciated.
 Post subject:
PostPosted: Sun Dec 14, 2008 7:00 pm
OAP
Has thanked: 187 times
Been thanked: 2115 times
You have a system restore built in. Try restoring to an earlier date before you uninstalled the programmes.
Start.
Accessories.
System tools.
System restore.
 Post subject:
PostPosted: Sun Dec 14, 2008 7:25 pm
Start.
Accessories.
System tools.
System restore.
Yes but the problem is that I cant get into the computer. I dont get that far before I get the blue page message.
Bernie
 Post subject:
PostPosted: Sun Dec 14, 2008 7:39 pm
OAP
The clever guys will be around later. :roll:
Have you got the xp disc.
 Post subject:
PostPosted: Sun Dec 14, 2008 8:02 pm
Unfortunately I havent. I dont recall getting one sent from Dell when it was initially delivered, I assumed because there is an internal restore system built into the PC.
thanks anyway
 Post subject:
PostPosted: Sun Dec 14, 2008 8:08 pm
OAP
I'm sure the guys will have a few ideas when they log on next.
 Post subject:
PostPosted: Sun Dec 14, 2008 10:10 pm
you need to boot into safe mode ..press F8 key when your pc starts up ..before it gets to the blue screen
should give you an option then to boot into safe mode ,do that then do a system restore from there
dont worry if you dont catch the F8 key right ,just keep trying until you do
 Post subject:
PostPosted: Mon Dec 15, 2008 7:48 pm
UHM Super Moderator
Has thanked: 4 times
Been thanked: 11 times
Unlikely to boot in Safe Mode wither.
Unless you can get hold of an XP disk, beg, steal or borrow, you're probably going to have to reinstall Windows.
Any chance?
http://www.FinchfieldIT.co.uk
 Post subject:
PostPosted: Mon Dec 15, 2008 9:39 pm
Any chance?
Well I have been trying unsuccessfully so far to borrow an XP disc, but I will keep on searching. Thanks for all replies.
Bernie
 Post subject:
PostPosted: Mon Dec 22, 2008 9:27 pm
Option 1) do press F8 but try last known good configuration
If it still doesn't work try option 2.
Option 2) You don't have to reinstall windows, but you'll need the xp CD plus a valid KEY.
All you have to do is:
- set the BIOS to boot from the CD
- wait for the post
- press "any key" to boot from the CD
- select install XP
- the installation will find your existing installation and ask you if you want to reinstall or Rapair
- Select reapair and go through the procedure.
btw you'll find your system going very fast after the restore ;-)
Hope this helps
rs232
 Post subject:
PostPosted: Tue Dec 23, 2008 8:02 pm
Deceased 21-10-2011 R.I.P
Has thanked: 9 times
Been thanked: 93 times
Check that Dell has not given you the XP set up on a virtual disk, on a partition of your main disk.
 Post subject:
PostPosted: Tue Dec 23, 2008 11:06 pm
Has thanked: 21 times
Been thanked: 27 times
F8
Safe mode is worth a go, might not work though.
last known good config hardly ever works sadly, neat idea, shame it doesnt work prop.
If safe mode doesnt work and If you have stuff you need to recover, then if you have access to another PC then download one of the live linux cds (ubuntu is the easiest), put it in, reboot, select "try ubuntu without making any changes to your computer" and backup from there, either to a usb stick, dvd recordables or to an external hard disk.
(lot of if's I know)
How old is the machine?
 Post subject:
PostPosted: Wed Dec 24, 2008 1:44 pm
If you didn't get an xp cd you probably have a recovery partition on your hard drive which you should be able to boot into before xp boots. Its normally pressing f10 but is different for different systems. What dell have you got?
The linux livecd is a good idea as a last resort to safe data then install it!!!
 Post subject:
PostPosted: Wed Mar 25, 2009 10:28 am
I can help you with a copy of xp but just try removing one of the memory mods if you have two in the computer just incase one has gone bad and restart after swaping them over but make sure you turn the power off before taking them out
Thanks For Yor Time
Time Lord
