It is currently Sat Oct 20, 2018 1:10 am
 Post subject: Stainless Sheets...
PostPosted: Tue Apr 17, 2007 4:33 pm
No, this is not a thread about low budget brothels... :grin:
Where is the cheapest place to buy stainless steel sheet? I am preparing a plan for a commercial kitchen, and want to line it with stainless. Anyone know any good suppliers for sheet steel?
Ta, Jock
That'll be that, then.
 Post subject:
PostPosted: Tue Apr 17, 2007 4:58 pm
Been thanked: 4 times
I'm about to have a custom fit splash back made in s/s and I just went thru' the yellow pages (or you could just google) and looked for a metal fabricator. They were more than happy to help and changed no more than an off the shelf square splashback - altho that wouldn't fit as my hood is curved.
 Post subject:
PostPosted: Tue Apr 17, 2007 5:03 pm
There isn't a whole lot of metal fabricators in my yellow pages!! I've tried some from google, just wondered if anyone had a number that was good. I don't need any fabrication, just plain sheet...
 Post subject:
PostPosted: Tue Apr 17, 2007 5:32 pm
http://www.metalsupermarkets.com/
One in glasgow, never used them, but they cut to size and deliver.
Its not the easiest stuff to work with.
Stella Stella Stella oy oy oy
 Post subject:
PostPosted: Tue Apr 17, 2007 6:54 pm
Cheers Jason,
I'll try and get a hold of them tomorrow.
As far as working with it goes, I'm hoping it shouldn't be too hard, as all I want to do is fasten it flat to walls for easy cleaning and dirt resistance... Can't be that hard... :?
 Post subject:
PostPosted: Tue Apr 17, 2007 7:23 pm
If your using this for catering it may be worth getting hold of your local health inspector to understand the correct type to use and also the requirements on how to fit it hygenically ie not leaving any groves where two surfaces meet which can result in a build-up of debri - only a thought :wink:
 Post subject:
PostPosted: Tue Apr 17, 2007 7:58 pm
skiking wrote:
If your using this for catering ... understand the correct type to use
Quite so. I've been advised by a number of sources that 304 grade will be adequate.. As to joining the gaps, I was hoping that snug fitting with an overlapping strip (say 50mm) would be sufficient. Any other points to consider?
 Post subject:
PostPosted: Tue Apr 17, 2007 8:14 pm
Ive only ever used 316 :shock:
 Post subject:
PostPosted: Tue Apr 17, 2007 10:21 pm
Has thanked: 96 times
Been thanked: 351 times
316 is food grade stainless steel.
If you need to bend it, get 316L.
 Post subject:
PostPosted: Tue Apr 17, 2007 10:59 pm
diesel demon
Has thanked: 170 times
Been thanked: 175 times
Jock, your in Stornoway, try HEB Engineering, failing that, Caledonian Sheet Metalwork or Inverfab, both in Inverness
i love being married
I have a soft spot for the wife, it's a peat bog just outside Ardross
Still Yes Highland
 Post subject:
PostPosted: Wed Apr 18, 2007 11:48 am
village idiot wrote:
try HEB Engineering
They seem to have disappeared - I was looking for them for some welding work... I'll try the Inverness connections tho, thanks for that!
 Post subject:
PostPosted: Thu Apr 19, 2007 5:25 pm
diesel demon
HEB Engineering used to be on Riggs Road, mind you, last time i was over Alec McArthur was still foreman, probably retired now :?
Still Yes Highland
