Page 1 of 1
[ 14 posts ] |
| Author |
Message |
cycloneuk
Posted: Thu Dec 15, 2011 1:08 pm |
| Newly registered Member |
Joined: Sun Feb 14, 2010 9:46 pm Posts: 54 Has thanked: 12 times Been thanked: 0 times
I have a old SM300 timer on a combi boiler which is broken and i have a new ST9100C programmer here. There was only 3 wires on the SM300, brown, blue and earth which turned the boiler on and off on a timer. Which terminals do i connect these to on the ST9100C? i have N L 1 2 3 4 and the earth block.
| Top |
thescruff
Posted: Thu Dec 15, 2011 2:21 pm |
| OAP |
Joined: Mon Mar 10, 2008 12:46 am Posts: 39986 Has thanked: 187 times Been thanked: 2115 times
Not possible, the old earth must be a phase, unless there's at least another wire.
Post what wires are connected to which number, a pic showing the connections would be better.
_________________ If you feel you have benefited from the Free advice given on the Forum, Please consider making a donation to UHM's Nominated charity, read all about it and donate here : donnas-dream-house-charity-t52110.html
| Top |
register or
log in
cycloneuk
Posted: Thu Dec 15, 2011 3:05 pm |
On the SM300 backplate the blue went to number 1, the brown to number 4 and the earth to the earth block. and there is N L 1 2 3 4 and the earth terminal on that back plate.
| Top |
register or
log in
thescruff
Posted: Thu Dec 15, 2011 3:09 pm |
| OAP |
You need an L & N for the clock.
1 & 4 are the switching pair the same as the St 9100.
What is the boiler make/model
| Top |
register or
log in
cycloneuk
Posted: Thu Dec 15, 2011 3:12 pm |
worcester 24cdi, i have just moved into the property. On the SM300 the on/off button worked but the timer dial didn't move.
| Top |
register or
log in
thescruff
Posted: Thu Dec 15, 2011 3:18 pm |
| OAP |
So 1 should go the LS in the boiler, and 4 should go to LR in the boiler.
Plus you also need the L&N to run the clock
Is there a room stat fitted.
I would change the ST 9100 for the Honeywell DT 92E programmable room stat.
| Top |
register or
log in
cycloneuk
Posted: Thu Dec 15, 2011 3:20 pm |
No room stat, so their should be 2 more wires?
| Top |
register or
log in
thescruff
Posted: Thu Dec 15, 2011 3:27 pm |
| OAP |
In that case the DT92E would be perfect.
Yes there must be an L&N for the old and new.
| Top |
register or
log in
cycloneuk
Posted: Thu Dec 15, 2011 3:29 pm |
I'm stuck with the ST9100C for now, i have connected LS and LR from the boiler to the positions you said above, but get no display on the ST9100C? will it need the other 2 wires?
| Top |
register or
log in
thescruff
Posted: Thu Dec 15, 2011 3:33 pm |
| OAP |
You need the L&N or it wont work, but neither would the old one
| Top |
register or
log in
cycloneuk
Posted: Thu Dec 15, 2011 3:52 pm |
It explains why the timer didn't work on the old one then, the on/off worked. Wonder who wired it up, anyway i guess i need to find some cable with another 2 wires or run another cable from the boiler.
| Top |
register or
log in
thescruff
Posted: Thu Dec 15, 2011 3:54 pm |
| OAP |
You need a 230vac supply, ideally it would be from the same fused spur feeding the boiler.
| Top |
register or
log in
cycloneuk
Posted: Thu Dec 15, 2011 3:55 pm |
The emtpy blocks on the boiler are NS & ST8, which position do they go on the ST9100?
| Top |
register or
log in
thescruff
Posted: Thu Dec 15, 2011 4:02 pm |
| OAP |
Ok follow this exactly.
Wire NS to N in the 9100.
Wire LS to L in the 9100.
Wire LR to 4 in the 9100.
Link L to 1 in the 9100.
and forget st 8 you are working in st 12.
| Top |
register or
log in
Page 1 of 1
[ 14 posts ] |
