It is currently Sun Apr 21, 2019 12:00 am
Post new topic Reply to topic  [ 19 posts ]  Go to page Previous  1, 2
PostPosted: Sun Apr 05, 2015 4:33 pm
Has thanked: 36 times
Been thanked: 260 times
that jig fin just has the std depth, the curve at the end is for run off
the jig that does a 23 and 10mm mitre is
http://www.its.co.uk/pd/JIGN179P-Unika- ... oCwxvw_wcB
its used in the same way bit the pegs are slightly offset
PostPosted: Sun Apr 05, 2015 4:44 pm
Has thanked: 1001 times
Been thanked: 1897 times
That's basically the jig howdens gave me for free a few years back speed. They aren't the top of the range but it's never let me down!
PostPosted: Sun Apr 05, 2015 9:01 pm
Has thanked: 42 times
Been thanked: 582 times
oops my mistake. i thought you had to flip it over.
PostPosted: Mon May 04, 2015 10:45 am
Has thanked: 3 times
Been thanked: 7 times
fin wrote:
http://www.its.co.uk/pd/KWJ700-Trend-Trade-Kitchen-Worktop-Jig-700mm-_TREKWJ700.htm
see how theres a different angle at each end?
use the shallow angle when theres a slight radius edge on the worktops. like a lot of howdens tops.
normal end for normal post formed type worktops.
however i just use my trend 1002 jig so i have to put the same on all the tops. or butt join em like speed said.
The shallow angle on the jig Fin is used for 45 degree corner mitres .. ie 22.5 degree for the old style corner canopies with a hob below and a 45 degree wall behind .
you should be abe to position the jig from measurements to get a shallow mason mitre . the measurement from the blade edge to the bush position is usually 8.5mm, so you can position the jig from this measurement.. you can even bend the joint with this method . conversely a projection mitre could be done , however this does require extra worktops , but means everything is a straight cut . not ideal.
