It is currently Fri May 25, 2012 5:35 pm
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 7 posts ]
 Post subject: Speedfit insert
PostPosted: Tue Sep 22, 2009 3:56 pm
Has thanked: 6 times
Could anyone please advise if I need to fit an insert into the 10mm speedfit pipe to connect to a Pegler Terrier 10mm push fit TRV. There is an o-ring inside the valve.
 Post subject:
PostPosted: Tue Sep 22, 2009 4:54 pm
OAP
Has thanked: 187 times
Been thanked: 2115 times
Never used the stuff so don't know.
Do they make 10mm inserts, if they do then yes.
 Post subject:
PostPosted: Tue Sep 22, 2009 7:04 pm
Has thanked: 51 times
Been thanked: 230 times
Yes you do need to fit an insert with any plastic pipe when using a compression fitting.
Speedfit used to make them specially for this without the rubber 'o' ring fitted so it would fit in the joint.
Don't know if they still do though :scratch:
Dave
www.drlgas.co.uk
 Post subject:
PostPosted: Tue Sep 22, 2009 8:15 pm
Mr. Grumpy
Been thanked: 32 times
The man at John Guest told me you must use a insert in all circumstances (in a plastic pipe obviously)
The preference is to use a superseal insert but if using a compression fitting its preferable to use a regular one, I think this was due to the head sticking out further though. Can't remember.
I love the stuff, even I can use it :lol:
 Post subject:
PostPosted: Tue Sep 22, 2009 9:05 pm
Hi gas4you. It's not a compression joint.Here's a pic of the valve. The elbow has a push fit connection on the bottom and I can see an o-ring and the metal grippers inside it. Just wondered if the insert was required. Thanks
 Post subject:
PostPosted: Tue Sep 22, 2009 9:37 pm
Yes, every time with any plastic :wink:
Dave
www.drlgas.co.uk
 Post subject:
PostPosted: Tue Sep 22, 2009 10:04 pm
Mr. Grumpy
I suppose its the same principal as the pushfit connections (i.e. tee's etc) you still need an insert
Users browsing this forum: Master of all and 3 guests
