Page 1 of 1
[ 2 posts ] |
| Author |
Message |
trevwhite
Posted: Sat Jul 31, 2010 11:12 pm |
| Newly registered Member |
Joined: Mon Mar 02, 2009 12:59 pm Posts: 45 Has thanked: 0 times Been thanked: 0 times
Hi all.
I have a doorway between two rooms that I want to block off. I actually want to use the door space for some shelving in one of the rooms. So was wondering how much sound proofing can I achieve with so 2 inches? I was thinking of putting a couple sheets of that acoustic sound proof plasterboard up? Is there a better way? How could are the sound proofing boards?
Cheers
Trev
| Top |
royaloakcarpentry
Posted: Sun Aug 01, 2010 12:42 am |
| Senior Member |
Joined: Sun Jan 24, 2010 1:48 pm Posts: 4152 Location: Essex Has thanked: 2 times Been thanked: 327 times
They will be better than normal plasterboard.
You could make a frame up. Board one side in sound board, put 25mm MDF in middle then sound board on other side. MDF has good acoustic properties and it will also give you a solid fixing point for you shelves.
| Top |
register or
log in
Page 1 of 1
[ 2 posts ] |
