Page 1 of 1
[ 3 posts ] |
| Author |
Message |
Raoul
Posted: Wed Apr 20, 2011 7:52 pm |
| Newly registered Member |
Joined: Wed Apr 20, 2011 7:33 pm Posts: 1 Has thanked: 0 times Been thanked: 0 times
I have a solar panel I want to mount on my garage roof, but I'm not sure if there's a way to do this and keep the roof properly sealed. The roof is plywood with a felt cover, not sure exactly what type of felt, but it's black and green with loose stones on top.
My basic idea would be to use some angle brackets bolted through the plywood into the beams underneath and attached the panel to the brackets. I'd have to cut some slits in the felt so I can peel it back to access the bare wood and then re-seal the felt back down, as well as seal the bolt heads somehow I guess. However, I've never worked with felt roofing before so I'm not sure if this is even feasible and what sealants etc. I would need. Can anyone provide some advice on this?
-- Thanks, Raoul.
| Top |
Simon Site Manager
Posted: Sun May 22, 2011 9:09 pm |
| Senior Member |
Joined: Tue Oct 27, 2009 8:55 pm Posts: 3177 Location: St Helens Merseyside Has thanked: 34 times Been thanked: 182 times
Hi Raoul,
Fitting solar or PV units to a flat roof is inadvisable (unless you live on the equator). South facing 30 deg pitch is best.
SSM
_________________ Measure twice, cut once!
| Top |
register or
log in
BillyGoat
Posted: Sun May 22, 2011 9:33 pm |
| Troll Headbutter |
Joined: Sat Jan 01, 2011 8:20 pm Posts: 1890 Has thanked: 77 times Been thanked: 130 times
I'd take the tails to the side of the garage if possible and leave the roof intact. Flat roofs have a habit of leaking when punctured.....
BG
| Top |
register or
log in
Page 1 of 1
[ 3 posts ] |
