| Author |
Message |
spiceweasel
Posted: Mon Oct 31, 2011 8:54 am |
| Senior Member |
Joined: Fri Feb 26, 2010 10:41 am Posts: 110 Has thanked: 53 times Been thanked: 0 times
hi all. had 2 plumbers round to quote for moving bathroom upstairs and both say that the downpipe which is currently being used as a rainwater pipe is actually a soil pipe originally and they can tap into this when putting bathroom upstairs. im happy to believe that it was originally a soil pipe but didn't know if you could have rainwater and shi-ite going into same pipe? thanks for your help
| Top |
thescruff
Posted: Mon Oct 31, 2011 9:07 am |
| OAP |
Joined: Mon Mar 10, 2008 12:46 am Posts: 39987 Has thanked: 187 times Been thanked: 2115 times
I think they're talking Cr@p.
What size pipe is it, and can we see the bottom or where it's connected.
It may well go into the drain or it may have a separate rainwater drain or soak-away, get it wrong and face a very big, pollution bill/fine
_________________ If you feel you have benefited from the Free advice given on the Forum, Please consider making a donation to UHM's Nominated charity, read all about it and donate here : donnas-dream-house-charity-t52110.html
| Top |
register or
log in
spiceweasel
Posted: Mon Oct 31, 2011 10:40 am |
| Senior Member |
thanks scruff, 2 images one is with the collar thing lifted out the way thanks for your time Attachment:
| Top |
register or
log in
thescruff
Posted: Mon Oct 31, 2011 10:54 am |
| OAP |
Only way to test is to lift an inspection chamber cover and pour some coloured water down the rainwater pipe.
The pipe would have to be changed to 110mm if there's a WC going into it.
I would check with the water Authority before you do anything.
| Top |
register or
log in
royaloakcarpentry
Posted: Mon Oct 31, 2011 1:10 pm |
| Senior Member |
Joined: Sun Jan 24, 2010 1:48 pm Posts: 4152 Location: Essex Has thanked: 2 times Been thanked: 327 times
spiceweasel wrote: hi all. had 2 plumbers round to quote for moving bathroom upstairs and both say that the downpipe which is currently being used as a rainwater pipe is actually a soil pipe originally and they can tap into this when putting bathroom upstairs. im happy to believe that it was originally a soil pipe but didn't know if you could have rainwater and shi-ite going into same pipe? thanks for your help Did you mean shi-ite as in a muslim or poopy dooh!
| Top |
register or
log in
spiceweasel
Posted: Mon Oct 31, 2011 2:02 pm |
| Senior Member |
thanks scruff, don't mind changing the pipe to 110mm, not sure i wanna open a can o worms informin water authority though but i'll happily lift inspection chamber and see if its its running into it. as i understand it, if it is indeed a soil pipe the guttering shouldn't be running into? if thats the case i'll happily move the rainwater downpipe and change the one thats there to a soil pipe? let me know if im anywhere near the mark, thanks again
| Top |
register or
log in
thescruff
Posted: Mon Oct 31, 2011 2:08 pm |
| OAP |
Lets put it this way.
If you pollute the water course/rivers, you could easily be looking at a £20k fine, and a clean up bill of half a million plus.
| Top |
register or
log in
royaloakcarpentry
Posted: Mon Oct 31, 2011 2:29 pm |
| Senior Member |
I thought the local water authority had to be informed when putting in an extra loo or moving one, anyway.
| Top |
register or
log in
thescruff
Posted: Mon Oct 31, 2011 2:33 pm |
| OAP |
royaloakcarpentry wrote: I thought the local water authority had to be informed when putting in an extra loo or moving one, anyway. They do, or did.
| Top |
register or
log in
spiceweasel
Posted: Mon Oct 31, 2011 2:55 pm |
| Senior Member |
already informed building control- never mentioned it, just said fill this form in hand over money and we'll check the work once it starts- even got it half price cuz doing a loft conversion as well, i told them i was unsure of soil pipe arrangement they just said get a qualified plumber and give me a list of tradesmen local. 2 of which i have had round. both shrugged shoulders and went yep no probs thats a soil stack anyway i'll boss into that. not tryin to cut corners but there is a lot of scaremongering goes on about building control when in fact they were very easy going about everything, give me loads of leaflets to help( mostly about loft fire safety) and said crack on. reason im on here is because i dont want to cut corners but don't want unecessary worry either.
| Top |
register or
log in
spiceweasel
Posted: Mon Oct 31, 2011 3:00 pm |
| Senior Member |
was something wrong with my previous post mods??
| Top |
register or
log in
thescruff
Posted: Mon Oct 31, 2011 3:02 pm |
| OAP |
No worry if you prove it's a main drain.
The building are there to help, and they will all the time you play with their ball.
| Top |
register or
log in
thescruff
Posted: Mon Oct 31, 2011 3:04 pm |
| OAP |
spiceweasel wrote: was something wrong with my previous post mods?? Why do you ask A mod would comment if it had been edited.
| Top |
register or
log in
moderator2
Posted: Mon Oct 31, 2011 3:09 pm |
| UHM Super Moderator |
Joined: Fri Jan 27, 2006 10:54 pm Posts: 1089 Has thanked: 30 times Been thanked: 55 times
spiceweasel wrote: was something wrong with my previous post mods?? Just looked in the logs. nothing on this thread. Did you hit the submit button Spiceweasel?
| Top |
register or
log in
spiceweasel
Posted: Mon Oct 31, 2011 3:16 pm |
| Senior Member |
obviously not.... DOH!!!!
| Top |
register or
log in
