Ultimate Handyman Home
Snotting
Post new topic   This topic is locked: you cannot edit posts or make replies.   Thank Post    www.ultimatehandyman.co.uk Forum Index -> Metalworking Forum
jason123
PostPosted: Tue Oct 09, 2007 11:42 pm    Post subject: Snotting Add User to Ignore List Reply with quote
It probably isnt the correct term, but dragging a blob of weld, keeping it hot and adding rod to it til you reach the other side. I call it stretching bogies or snotting. Today I had a 20mm gap to fill tig welding, it was a tear in the SS, to make up a plate to fit to weld quickly would have taken a week, I chose snotting. I do this at about 6mm intervals until I have a continuous row or snots. I can then fill between each much easier, is there a term for this?
Stella Stella Stella oy oy oy
Back to top
jason123
PostPosted: Tue Oct 09, 2007 11:45 pm    Post subject: Add User to Ignore List Reply with quote
Forgot to mention 50mm box section 2mm wall with a 20mm gap between torn mitres.
Back to top
Wood Magnet
PostPosted: Wed Oct 10, 2007 1:23 am    Post subject: Add User to Ignore List Reply with quote
I call it bridging, but thats just my term for it. Wink
People forget how fast you did a job - but they remember how well you did it.
I no longer skinny dip, i chunky dunk these day's.
Back to top
jason123
PostPosted: Wed Oct 10, 2007 8:57 am    Post subject: Add User to Ignore List Reply with quote
That sounds better Thumbright
Back to top
Hitch
PostPosted: Wed Oct 10, 2007 5:40 pm    Post subject: Add User to Ignore List Reply with quote
Welding up a f*ing gert gap, is what i call it. Laughing
Sounds like a bit of a mess really Jas Wink
That amount of heat must have pulled it allsorts of funny shapes Shocked
Cut 2 plates, to go on the outside of the box and 2 triangles for the sides. Fuse it all together, then cap off the inside of the triangles with a final plate. Thumbright 30 mins work Smile
Back to top
jason123
PostPosted: Wed Oct 10, 2007 7:00 pm    Post subject: Add User to Ignore List Reply with quote
If only we had the steel stock hitch, we get asked to make the most obscure stuff, there is a floor scraper at work no one likes using, its got a SS flat blade and a 6 foot handle made out of
30mm solid round bar, weighs a ton Thumbright nobodys broken it yet. We didnt have any pipe in at that time.
Back to top
Hitch
PostPosted: Wed Oct 10, 2007 7:19 pm    Post subject: Add User to Ignore List Reply with quote
Cut the floor scrapper up, to repair the box section. Thumbright
Back to top
Display posts from previous:
Post new topic   This topic is locked: you cannot edit posts or make replies.    Thank Post    www.ultimatehandyman.co.uk Forum Index -> Metalworking Forum All times are GMT
Page 1 of 1
