It is currently Fri May 25, 2012 8:32 pm
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 9 posts ]
PostPosted: Thu Dec 08, 2011 4:35 pm
I'm trying to locate a replacement pop-up bathroom sink plug which seems to be smaller than the standard (1 1/4") size. The plug is 35mm at it's widest diameter, the rubber seal being 2 or 3 mm smaller.
Any ideas where I might be able to get one? I can't see a manufacture name on the sink, the tap is as an Aumix but not sure that's related.
Google has failed me!
PostPosted: Thu Dec 08, 2011 4:40 pm
Has thanked: 144 times
Been thanked: 217 times
Is there a lever on the back of the tap to pop the waste up? If so then the waste more than likely came with the tap itself.
What is wrong with the waste anyhow?
Professional Kitchen & Bathroom Fitters | Master Painters and Decorators | Brighton & Hove
PostPosted: Thu Dec 08, 2011 4:47 pm
Yes there is a lever on the tap. I haven't had much luck tracking down "Aumix" products though but will have another Google...
The plug pictured is from the main bathroom, the same sized plug was missing from the ensuite bathroom when we moved into the house! Hence looking for another one.
PostPosted: Thu Dec 08, 2011 4:50 pm
Has thanked: 166 times
Been thanked: 169 times
does this match?
http://goo.gl/Knf2L
- Dave
http://www.pamperhouse.net
http://www.invertedcircle.co.uk
PostPosted: Thu Dec 08, 2011 4:55 pm
root wrote:
does this match?
http://goo.gl/Knf2L
Nope, that's a standard 1 1/4" unfortunately. Comparing mine to one of those in a shop mine was about 3-4mm smaller in diameter.
PostPosted: Thu Dec 08, 2011 5:29 pm
what is broken on the plug? also....... can you take a picture of the taps, one of the plumbers may recognise the model :-)
- Dave
PostPosted: Thu Dec 08, 2011 6:29 pm
Nothing, as I said above I just need another one of the little buggers :)
Here you go;
PostPosted: Thu Dec 08, 2011 7:48 pm
Been thanked: 614 times
:dunno: Every online search I've done leads me back to Grohe...
Only thing I can suggest from here would be to take the part (And your ruler/measure) into independent plumbers merchant to see if they have anything...
PostPosted: Thu Dec 08, 2011 8:03 pm
OAP
Has thanked: 187 times
Been thanked: 2115 times
lunns.
Users browsing this forum: carder1 and 18 guests
