It is currently Fri May 25, 2012 8:31 pm
 Post subject: Small Scratch In Marble
PostPosted: Thu Dec 01, 2011 11:09 pm
Has thanked: 19 times
Been thanked: 3 times
Just had the guy come tho fit the mantle and half ready for his fire fitter to install the fire. When we went to take the half out of the garage there are a few smell scratches on the marble from it being taken out of the old house and the removal company being careless, but they won't own upto it as it's been more than a month and we couldn't check it as they decided to put it at the back ::b . Will these be able to buff out and if so is this a speacialist job or can I do it if I pick up a few supplies. Cheers
PostPosted: Fri Dec 02, 2011 12:23 am
Couldn't sleep so took a few pictures. Throw the last one in as I love the new floor
File comment: Scratch 1
File comment: Scratch 2
File comment: Scratch 3
File comment: Just thought I'd add this as it shows the floor that he is fitting aswell.
PostPosted: Fri Dec 02, 2011 9:13 am
Has thanked: 43 times
Been thanked: 43 times
A couple of things. Your marble is man made as opposed to marble ... it is made by big chunks of marble + resin or cements to glue them together. You might find how to polish marble but the advice may not apply to man made marble.
Do not use any acids. Usually the complete surface of marble is polished (using abrasive pastes etc) and the shine - depending on the marble - comes from very find grinding. Man made material may have polish applied to it. I don't have any experience (or bottle rather) to suggest how you might try to polish off the scratches ... but whatever you do use the finest grinding material (steel wool, emery paper or something else). The problem is you will be touching an area wider than the actual scratch and may make it much worse.
I have a tiny problem (similar to yours) and I bought this ... http://www.briwax.co.uk/products/marblewax.html ... but I have not done anything. Enough dust on the marble covers everything.
If the wood surround is not fitted ... you can experiment with the area that will be covered by the surround.
Users browsing this forum: speed and 3 guests
