It is currently Fri Feb 23, 2018 4:28 pm
Visit Thermo worx
 Post subject: skirting gap to floor?
PostPosted: Fri Apr 04, 2008 9:09 pm
do i leave a gap in between the skirting and the floor for the carpet to fit under?
:hello2:
 Post subject:
PostPosted: Fri Apr 04, 2008 9:22 pm
Forum Chatterbox
Has thanked: 30 times
Been thanked: 4 times
I've never seen it done like that. :scratch: You have carpet grippers nailed around the room's perimeter up to the skirting with underlay attached to the subfloor and carpet stretched on top. Well our house did, I removed it all! :lol:
A good link
Louise
Trainee Tough Mudder
 Post subject:
PostPosted: Fri Apr 04, 2008 9:25 pm
Jack Of All Trades
Has thanked: 190 times
Been thanked: 259 times
Like Blu says, the carpet fitter will fit to suit!
By eck! ©
 Post subject:
PostPosted: Fri Apr 04, 2008 10:59 pm
Craftsman Carpenter
Been thanked: 1 times
there are two schools of thaught on this matter
some say no gap for carpet, others say allow some gap
 Post subject:
PostPosted: Fri Apr 04, 2008 11:04 pm
Jack Of All Trades
I always leave a few mm anyway, but it's nothing to do with allowing for the carpet!
By eck! ©
 Post subject:
PostPosted: Wed Apr 09, 2008 12:22 am
Been thanked: 6 times
The only case you should leave a gap is if your floor is not level. You would mark a level line around the walls and fit your skirting to that.
Of course there would be gaps and no gaps depending on the floor.
The reason for this if the wallpapering had a pattern or the floor was so bad it would look obvious
So no do not leave a gap. :wink:
 Post subject:
PostPosted: Wed Apr 09, 2008 12:28 am
Jack Of All Trades
b*llox, I always leave a gap!!..........fit the skirting level a few mm above the floor.
By eck! ©
 Post subject:
PostPosted: Wed Apr 09, 2008 12:48 am
Well some do some dont :wink:
Dont worry I am not saying you are wrong and will not resort to verbal abuse.
But can I ask what the purpose of the few mm gap is?
Carpentry and Joinery Woodworking Information
 Post subject:
PostPosted: Thu Apr 10, 2008 12:00 am
I fitted new skirting boards in my last house, I just fitted them as near to the floor as they would go.
In the bedrooms we had cream coloured carpets fitted. After about 6 months we noticed that the edge of the carpet in the 2 front bedrooms along the front outside wall of the house had discoloured & was quite dirty. The dirty mark was a strip approx 1 inch wide :scratch:
After a bit of thought I could only put this down to dust from inside the cavity wall / under the floorboards being blown through the gap between the skirting & the floor when the wind hit the front of the house, as the same coloured carpet in the back bedroom was unmarked.
So based on my experience I would advise sealing any gap between the skirting & the floor. :thumbright:
 Post subject:
PostPosted: Thu Apr 10, 2008 12:55 am
This is why I would not leave a gap between skirting and floor. Even more so on a older property where there is more dust.
 Post subject:
PostPosted: Thu Apr 10, 2008 7:52 am
Borders Bodger
In my last house I put down engineered wood flooring over the old floorboards that had been flat edged and had the usual gaps between planks.
After I fitted the skirting, I left a gap of about 1mm to allow ease of decoration - avoiding paint on floor when doing skirting - as well as for slight movement.
I found that draftiness of the floorboard had turned into a quite noticable wind in that 1mm gap as the air found an exit at the floorboard edge, flooring expansion gap and skirting gap - Brrrrr
Doing the flooring in this house I still left a slight gap (for decor and movement) but this time I sealed behind by allowing the foam membrane underlay to run up the wall a couple of inches
