It is currently Fri May 25, 2012 8:22 pm
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 2 posts ]
 Post subject: Skim on skim
PostPosted: Sun Sep 11, 2011 12:49 pm
Has thanked: 43 times
Been thanked: 43 times
What is the correct procedure for a 2nd skim coat? How long should the first coat be left for ... before I have to PVA again. The plaster is multifinish.
Cheers
Charles
PS. I might have 1 or 2 hollow areas to fill in a bit 1-2mm extra seems to be needed ... not interested in skimming for catching imperfections ... I can fix those.
 Post subject: Re: Skim on skim
PostPosted: Sun Sep 11, 2011 6:20 pm
Has thanked: 58 times
Been thanked: 272 times
You sohouldn't PVA between coats. Typically between 15 and 45 minutes between coats depending on temperature, humidity.
cron
