It is currently Thu Apr 19, 2018 12:37 pm
Visit Thermo worx
PostPosted: Thu Mar 15, 2012 9:43 am
Has thanked: 5 times
Been thanked: 26 times
Does anybody know where to find information on how to size up an accumulator
taking into account the flow rate and usage (no of showers etc)
Also.
when having the choice what would you do
install an accumulator, or a home booster system from Grundfos - Noise is no issue as the unit will be intalled in a seperate plant room next to the boiler and hot water storage tank
PostPosted: Thu Mar 15, 2012 2:03 pm
Has thanked: 1075 times
Been thanked: 799 times
It would depend on what your existing incoming water mains supply is like, pressure & flow. For large demands a accumulator is useless, you'll required a large breaker tank & pump.
HTH
Time-served Plumber/Heating Engineer & general wind-up merchant.
The Plumbers Anthem
If you have found my help or tips useful please donate here. Thank You;
Gas Safe RGI
Scottish, British & Proud.
I'm not or never claimed to be Chris Williams.
PostPosted: Thu Mar 15, 2012 3:20 pm
HTH
static pressure is 2.5 bar. and flow rate is arround the 18 liters per min,
and we have arround 3 showers, they will ofcourse not be used at the same time al the time, but need to size it properly
the current set up will not suffice, and you will get starvation. so therefore you can use an accumulator, (please explain as to why it is not usable for large demands?).
In principle there is no need for a pump with a static bar of 2.5 but it having it can help (the house is over 3 floors- with one shower on the top floor). an accumulator works on the static pressure of the mains and is just a massive expansion tank which fills up when there is no demand or the demand is less then the flow rate requested.
when flow rate exceeds the current 18l per min the accumulator will supply the shortfall under the current static pressure
what i need/like to know what is what kind of accumulator do i need to have to overcome that starvation at the showerhead
PostPosted: Thu Mar 15, 2012 4:20 pm
With a static pressure that low, I'd hate to think what your dynamic pressure is!! Don't fit an accumulator mate, your mains water is not up to it. Plus, if there's a water main burst in any part of their network, you'll be knackered!! I'd avise a breaker tank & pump.
HTH
The Plumbers Anthem
Gas Safe RGI
PostPosted: Thu Mar 15, 2012 9:36 pm
What is a breaker tank doing different then an accumulater or a Grundfos home booster system
PostPosted: Thu Mar 15, 2012 9:55 pm
UHM Super Moderator
Has thanked: 180 times
Been thanked: 428 times
Around half the volume of an accumulator is useful as a rough rule of thumb so a 300l one will give you roughly 150l of boosted supply :wink:
PostPosted: Fri Mar 16, 2012 8:10 am
With a breaker tank, you can store as much low pressure water as you wish & with a pump you can boost that supply. So you'll have an endless supply.
With any high demand system & a acculmulator, the dynamic water pressure & flow rate is very important.
The Plumbers Anthem
Gas Safe RGI
PostPosted: Mon Mar 19, 2012 11:47 am
The flow rate that i have measured is 15l per minute and the static pressure is 2.5 bar
the property is over 3 floors. and will be newly equiped with an megaflow system - the plumber i have hasn't done any installations of an accumulator in a domestic dwelling
the 2.5 bar is according to the plumber enough, but the concern is the following 1 flow rate for 3 showers , and will the 2.5 bar still be enough on the top floor wich is about 9 meters above his measure point?
PostPosted: Mon Mar 19, 2012 3:03 pm
Well, 3 showers @ 12Ltr each = 36Ltr!!
Too many ifs & buts, I'd fit a breakers tank & pump.
The Plumbers Anthem
Gas Safe RGI
