It is currently Mon Jul 23, 2018 11:01 am
PostPosted: Sun Oct 29, 2017 9:29 am
Has thanked: 35 times
Been thanked: 1 times
Can anyone advise me to why I should use cement, sand and aggregate over cement and ballast to make concrete? Seems far easier and simpler to make from just cement and ballast.
PostPosted: Sun Oct 29, 2017 9:41 am
Has thanked: 565 times
Been thanked: 1668 times
The sand helps fill the voids between the aggregate and with the cement it gives a strong hard mix afetr it is tamped well to compress and drive out the air. Varying quantities of each component can give differing load, durability and flex capabilities I think.
Painting with BIN
For this message the author dewaltdisney has received thanks - 2: multiman, The Z'eer
PostPosted: Sun Oct 29, 2017 10:15 am
Has thanked: 46 times
Been thanked: 53 times
Just use cement, bagged ballast and water.
I think this is one of those "depends where you are in the UK questions", in the South what we call ballast, as in ton bags, or 20 ton loose loads of the stuff is ready to go in the mixer.
But ooop Norf, according to what I've read on here in older posts, I think what they call ballast is something different, i.e just the stones, so you would need to add sand.
www.oakovercontracting.co.uk
For this message the author Handyman in Sussex has received thanks - 3: james232, multiman, The Z'eer
PostPosted: Sun Oct 29, 2017 10:27 am
Has thanked: 11 times
Been thanked: 60 times
Ask for ballast in the South West and think you have just landed from Mars. Known as All In here.
Most people use ballast etc for concrete nowadays, but years ago mixes such as 1/3/6 or 1/2/4 were used.
For this message the author stuart45 has received gratitude : multiman
PostPosted: Sun Oct 29, 2017 1:56 pm
Has thanked: 49 times
Been thanked: 518 times
It depends on its use and if its internal or external, 2 sharp, 3 Ballast and 1 dust (cement) is a fairly universal mix it tamps down nicely and can be float finished
Quantity's can be referred to as a spade or bag depending on how much you need
For this message the author Bob225 has received thanks - 2: james232, The Z'eer
PostPosted: Sun Oct 29, 2017 7:32 pm
Has thanked: 1452 times
Been thanked: 3725 times
"all in one ballast" where I live...
PostPosted: Sun Oct 29, 2017 9:03 pm
Has thanked: 41 times
Been thanked: 82 times
Here in West Wales it's "all-in" at the builders' merchant ("850kg min." bag) and "ballast" at Wickes, presumably a national terminology - same stuff. I've always taken it to mean that "all-in" means, sand included in the correct ratio. Then the amount of cement determines the strength.
For this message the author arco_iris has received gratitude : james232
PostPosted: Mon Oct 30, 2017 11:14 am
Thanks for the science there, I believe it's a 1 cement to 5 ballast that's been recommended.
PostPosted: Mon Oct 30, 2017 11:16 am
With reference to your ratio, if I was to go the cement plus ballast route, the equivalent would be a 1:5 ?
PostPosted: Mon Oct 30, 2017 11:19 am
I'll go with that for the sake of convenience and less open to issues. A cement/ballast does seem to be more conventional.
PostPosted: Mon Oct 30, 2017 3:34 pm
5 and 1, or 10 and 2 be it sand, ballast or sharp or a mix - the more sand you use the weaker the mix
For this message the author Bob225 has received gratitude : The Z'eer
PostPosted: Sat Nov 04, 2017 7:53 pm
Cheers Bob :) I went with a 1 cement to 4 ballast. Oddly the concrete has khaki like tone to its appearance, even though it was poured 48 hours back.
Users browsing this forum: Bing [Bot] and 1 guest
