Page 1 of 1
[ 9 posts ] |
| Author |
Message |
lagi
Posted: Wed Sep 08, 2010 7:12 am |
| Senior Member |
Joined: Mon Dec 22, 2008 6:09 pm Posts: 1520 Has thanked: 75 times Been thanked: 35 times
I may now have to look at fitting my shower with a riser kit.
1). Firstly, i have fitted 18mm wbp plywood to the joist floor and this has been securely screwed and noggined to stop any flex. Can i fit a shower tray with riser kit ontop of this? (20mm of adjustability between a minimum height of 140mm and a maximum of 160mm. Please note: This height is to the top of the tray)
2). Its a quadrant shower but the waste will be on the other side, because this is now on a riser kit will it be able to diagonally go across to the other side and along a wall out? Or will i have to look at a waste on the same side as the pipe is going to be run?
My starter questions.
| Top |
thescruff
Posted: Wed Sep 08, 2010 10:57 am |
| OAP |
Joined: Mon Mar 10, 2008 12:46 am Posts: 39131 Has thanked: 181 times Been thanked: 1983 times
You can go through he wall first and fit a rodding eye. Are you sure we haven't done these questions before
_________________ --------------------------------------------------------------------------------------------------- If you feel you have benefited from the Free advice given on the Forum, Please consider making a donation to UHM's Nominated charity, read all about it and donate here : donnas-dream-house-charity-t52110.html
| Top |
register or
log in
register or
log in
thescruff
Posted: Thu Sep 09, 2010 12:17 pm |
| OAP |
 What's a riser kit
| Top |
register or
log in
lagi
Posted: Thu Sep 09, 2010 12:23 pm |
| Senior Member |
If you have a shower that sits on the floor and you can't get the waste under for any reason (like concrete floors.) you fit a riser kit to rise it off the gournd. Its just legs that go in the bottom and a piece of moulding to hide the new height.
I think the clue is in the name.
| Top |
register or
log in
thescruff
Posted: Thu Sep 09, 2010 12:28 pm |
| OAP |
No clue in the name, I would assume it was something to do with the shower control.
You can use the kit or build a platform to stand the tray on and then tile it all.
| Top |
register or
log in
lagi
Posted: Thu Sep 09, 2010 12:31 pm |
| Senior Member |
Yes, but can the waste run diagonally as in the picture???
| Top |
register or
log in
thescruff
Posted: Thu Sep 09, 2010 12:36 pm |
| OAP |
Yes, just put a tee on the change of direction for access.
| Top |
register or
log in
lagi
Posted: Thu Sep 09, 2010 12:43 pm |
| Senior Member |
Thanks, now i can look for the kit.
| Top |
register or
log in
Page 1 of 1
[ 9 posts ] |
