Page 1 of 1
[ 13 posts ] |
| Author |
Message |
daveday
Posted: Thu Sep 09, 2010 6:49 am |
| Newly registered Member |
Joined: Thu Sep 09, 2010 6:43 am Posts: 6 Has thanked: 1 times Been thanked: 0 times
Hi, I've had this problem for a few months now and I can't figure out what's causing it.
I have a combi boiler installed and a mixer shower above the bath. The shower will drip quite badly whenever a tap is opened ANYWHERE else in the house. It never drips other than this.
Any ideas what the problem could be?
Many thanks, Dave
| Top |
thescruff
Posted: Thu Sep 09, 2010 12:23 pm |
| OAP |
Joined: Mon Mar 10, 2008 12:46 am Posts: 39133 Has thanked: 181 times Been thanked: 1983 times
Could be the shower is being held off by the pressure or a vacuum.
Next time you have a shower, dry the rose jets with a towel, then try another tap.
When you say open another tap, is it the same hot and cold.
_________________ --------------------------------------------------------------------------------------------------- If you feel you have benefited from the Free advice given on the Forum, Please consider making a donation to UHM's Nominated charity, read all about it and donate here : donnas-dream-house-charity-t52110.html
| Top |
register or
log in
daveday
Posted: Thu Sep 09, 2010 12:37 pm |
ok I'll try that when I get home thanks. It happens with both hot and cold (although I'd say it's more noticeable when turning a hot tap). Thanks, Dave
| Top |
register or
log in
thescruff
Posted: Thu Sep 09, 2010 12:42 pm |
| OAP |
Post a pic of the shower fittings if it doesn't work.
| Top |
register or
log in
daveday
Posted: Mon Sep 13, 2010 6:15 pm |
Hi, Well I tried what you said and also de-limescaled the shower head. I've tested it for the last 48 hrs and its still the same :-( Here is a photo of my shower. Thanks, Dave Click for full size - Uploaded with Skitch
| Top |
register or
log in
thescruff
Posted: Mon Sep 13, 2010 10:24 pm |
| OAP |
Can only think there's a weak spring or component in the valve in that case.
| Top |
register or
log in
Colour Republic
Posted: Mon Sep 13, 2010 10:32 pm |
| Senior Member |
Joined: Thu Jul 29, 2010 2:08 am Posts: 1395 Location: Brighton & Hove Has thanked: 136 times Been thanked: 194 times
When you take the shower hose off, does the thermostatic valve drip constantly?
| Top |
register or
log in
daveday
Posted: Tue Sep 14, 2010 6:03 pm |
Hi, If I remove the hose the thermostatic valve will drip approximately twice a minute. Are we getting somewhere?
| Top |
register or
log in
Colour Republic
Posted: Tue Sep 14, 2010 10:33 pm |
| Senior Member |
It shouldn't drip at all, as Scruff says the drip is being held off by a vacuum and also the minimal amounts of pressure in the shower hose, which suddenly releases when there is a change in pressure to the system.
You could try removing the bar and cleaning, it is possible that there is debris stoping it from closing properly, it looks as though it's a fairly new shower. When you remove the shower bar there should be 2 rubber filter washers on the end of the tails, check to see if these are clogged up, if there is a lot of debris and the shower is new, it could indicate that the pipework was not flushed through before the shower was fitted. Thermostaic mixers don't like flux very much.
| Top |
register or
log in
gas4you
Posted: Wed Sep 15, 2010 8:31 am |
| Senior Member |
Joined: Mon Apr 13, 2009 8:03 pm Posts: 3395 Has thanked: 43 times Been thanked: 213 times
Does the combi attempt to fire up for a second or two when this happens?
_________________ Dave
www.drlgas.co.uk
| Top |
register or
log in
daveday
Posted: Wed Sep 15, 2010 1:22 pm |
Well I removed the mixer bar and cleaned the inside of the pipework (there was a bit of brick dust in the hot pipe). I then removed the valve from the mixer bar and when the valve is completely shut off a small amount of air can still pass through when I blow through it. Is this normal?
I've found a new replacement on eBay for £85 (Triton Aire Bar Mixer Shower)
Does anyone know if you can replace just the valve or do I need a complete new shower?
Thanks guys I appreciate your help.
Dave
| Top |
register or
log in
Colour Republic
Posted: Wed Sep 15, 2010 1:59 pm |
| Senior Member |
Just replace the valve is fine, pipe centres should be 150mm, undo one replace with another
| Top |
register or
log in
daveday
Posted: Wed Sep 15, 2010 2:06 pm |
Ok thanks a lot, I'll give that a try.
| Top |
register or
log in
Page 1 of 1
[ 13 posts ] |
