Quote:
i said in my first post its a broken hinge device - you said "is that a hinge?"
I don’t' see a problem with confirming what the item in question is. People use the strangest of terminology to describe items. From the picture, it looked identical to a magnetic catch to a shower cubicle I installed earlier this week.
Quote:
I said in my first post "its broken" - you said "what is wrong with it?"
So? Items can be repaired sometimes......
Quote:
I said in my first post "I’ve no idea who makes it" - you said "is there a manufacturer?"
Well, there could have been a name on the shower cubicle or you might have known which company installed it, which could have allowed someone to say "Ah, company X usually fits product Y". Did you even look?
Again, the cubicle I just installed has a name on it - not in the most obvious place, but it's there.
Quote:
I said in my first post "..I’ve no idea where to get another" - you said "do you know where it was purchased from?"
Same as above.
Quote:
If it took a photo of the whole enclosure, you wouldn't be able to see the part, as its about 3 inches long. It's not about free advice, it's about time wasting. I'm a member of several other forums that offer help on anything from linguistics to music, and whenever I see anything i can help with then i do. If it's something i can't help with then i don't respond.
Same as above.
Quote:
It's not about free advice, it's about time wasting. I'm a member of several other forums that offer help on anything from linguistics to music, and whenever i see anything i can help with then i do. If it's something i can't help with then i don't respond.
I might post on your music forum, I'm not sure I'm playing my tiny violin properly......
