Page 1 of 1
[ 9 posts ] |
| Author |
Message |
nobby1234
Posted: Sat Dec 31, 2011 7:22 pm |
| Newly registered Member |
Joined: Sat Dec 31, 2011 6:58 pm Posts: 4 Has thanked: 0 times Been thanked: 0 times
Hi have just been given a Stuart Turner Monsoon 3.0 bar twin shower pump. My existing pump has 15mm inlet and outlet but the Monsoon pump has 22mm. Was told that I need to replace all the 15mm pipewwork to and from the pump with 22mm as there would not be enough flow to activate the pump. Is the correct ? or can i just fit speedfit adaptors to connect to the inlet and outlet of the new pump
| Top |
thescruff
Posted: Sat Dec 31, 2011 10:46 pm |
| OAP |
Joined: Mon Mar 10, 2008 12:46 am Posts: 39987 Has thanked: 187 times Been thanked: 2115 times
Not really much point putting a 3bar pump on 15mm.
Which model are you getting.
_________________ If you feel you have benefited from the Free advice given on the Forum, Please consider making a donation to UHM's Nominated charity, read all about it and donate here : donnas-dream-house-charity-t52110.html
| Top |
register or
log in
nobby1234
Posted: Sun Jan 01, 2012 11:39 am |
not sure of model on pump it reads w input 850 A 3.7 duty head 29 metres @ 9 l/min duty head 1 metres @67 l/min head max 34 metres maximum working pressure 6.0 bar part code 14.50.46078
| Top |
register or
log in
thescruff
Posted: Sun Jan 01, 2012 12:09 pm |
| OAP |
Feed ins need to be 22mm, I would change both in and out.
Is it a negative or positive head pump
| Top |
register or
log in
Razor
Posted: Sun Jan 01, 2012 12:30 pm |
| Senior Member |
Joined: Wed Nov 14, 2007 10:21 pm Posts: 5141 Location: Northampton Has thanked: 76 times Been thanked: 373 times
That's a nice pump. As Scruff says it needs to be plumbed in properly or it will die quite quickly.
22mm supplies to each side, cold direct off the cistern and hot best supplied via a cylinder flange. And make sure the stored water isnt over 55 degrees C
_________________ As always help on here is free, however if you think you have saved a decent sum of money why not click the link to find out about the charity we're currently supporting? A couple of quid makes a real difference. donnas-dream-house-charity-t52110.html
| Top |
register or
log in
thescruff
Posted: Sun Jan 01, 2012 12:37 pm |
| OAP |
And you'll probably need 80-100 gallons of stored water depending on the recovery rate.
| Top |
register or
log in
nobby1234
Posted: Sun Jan 01, 2012 1:08 pm |
i presume its a positive head as the cold feed comes direct from the tank in the loft is that what you mean ?
| Top |
register or
log in
thescruff
Posted: Sun Jan 01, 2012 2:16 pm |
| OAP |
No they manufacture two types of pump, one works with pressure drop and the other with flow.
| Top |
register or
log in
nobby1234
Posted: Sun Jan 01, 2012 3:01 pm |
just put part number into stuart turner website and it says its a Monsoon 3 bar twin 230/1/50 can u tell from that wether its positive or negative head ?
| Top |
register or
log in
Page 1 of 1
[ 9 posts ] |
