| Author |
Message |
wickerman999
Posted: Wed Jul 01, 2009 1:28 pm |
| Newly registered Member |
Joined: Fri Dec 05, 2008 9:16 pm Posts: 43 Has thanked: 0 times Been thanked: 0 times
Hello all,
Please could someone help me, I have a Worcester Bosch 24CDI combi boiler and a Mira 415 mixer shower, I have just come back from a weeks holiday and when you turn the shower on it goes hot then goes luke warm back to hot, I have watched the boiler when this happens and the hot water demand light stays on but for some reason the pilot light goes off and then starts back up again, it repeats this every other minute or so. It only happens with the shower it doesn't seem to happen with the warm bath tap or any other hot water tap.
The pressure on the boiler is 1 bar at rest.
What do you think it could be and how can I rectify the problem?
Many thanks
Mark
| Top |
thescruff
Posted: Wed Jul 01, 2009 1:44 pm |
| OAP |
Joined: Mon Mar 10, 2008 12:46 am Posts: 39987 Has thanked: 187 times Been thanked: 2115 times
Hi
The gauge on the boiler measures the system pressure (heating) and is not connected to the hot water at the taps.
Could be just the valve needs a service, check the rose is clean and all the holes are clear, also lower the hand set to see if it makes any difference.
_________________ If you feel you have benefited from the Free advice given on the Forum, Please consider making a donation to UHM's Nominated charity, read all about it and donate here : donnas-dream-house-charity-t52110.html
| Top |
register or
log in
rio.
Posted: Wed Jul 01, 2009 3:51 pm |
| Senior Member |
Joined: Fri Nov 14, 2008 4:47 pm Posts: 1051 Location: surrey Has thanked: 0 times Been thanked: 5 times
if the shower rose isnt blocked, it could be that the inner rubber liner of the shower flex is failing.
| Top |
register or
log in
Posted: Wed Jul 01, 2009 7:26 pm |
| Senior Member |
Joined: Fri Jan 20, 2006 5:51 pm Posts: 3209 Location: Essex Has thanked: 17 times Been thanked: 266 times
| Top |
register or
log in
gas4you
Posted: Wed Jul 01, 2009 7:34 pm |
| Senior Member |
Joined: Mon Apr 13, 2009 8:03 pm Posts: 3577 Has thanked: 51 times Been thanked: 230 times
Does it happen on another hot tap if you run it slowly?
_________________ Dave
www.drlgas.co.uk
| Top |
register or
log in
wickerman999
Posted: Wed Jul 01, 2009 8:17 pm |
Thanks for all of your answers.
I have tried this on another tap at low flow and they work fine, the hot water comes out and stays like it.
As far as I know the shower is the original one in the house and has never had a service, so I am thinking it could be that, it's about 10 years old.
| Top |
register or
log in
wickerman999
Posted: Wed Jul 01, 2009 9:43 pm |
I have taken the cartidge out and looked at it, when you blow on the cold water side the ball inside moves on the pressure allowing a flow through but when I tried it on the hot side it didn't move but you can move it by pressing a needle against it and it doesn't take much force..
Is this normal?
| Top |
register or
log in
Posted: Wed Jul 01, 2009 11:35 pm |
| Senior Member |
I think that would be it....try a call to Mira technical advice line. They will be able to tell you if you need a cartridge or repair kit.
| Top |
register or
log in
wickerman999
Posted: Tue Jul 07, 2009 2:26 pm |
Hi all,
I have bought the 902.55 black cartirdge for the shower, fitted it and it has made no difference at all, so it must be the boiler...
I have booked an engineer to have a look tomorrow.
| Top |
register or
log in
thescruff
Posted: Tue Jul 07, 2009 2:47 pm |
| OAP |
How can it be the boiler, if the other outlets are fine.
| Top |
register or
log in
gas4you
Posted: Tue Jul 07, 2009 5:12 pm |
| Senior Member |
I would go for the plate HE blocked on the system side, which was what my previous question was pointing to.
www.drlgas.co.uk
| Top |
register or
log in
rio.
Posted: Wed Jul 08, 2009 6:58 am |
| Senior Member |
if the other taps are ok at low flow, as said it cant be the boiler
did you check the hose?
let us know what engineer finds please.
| Top |
register or
log in
wickerman999
Posted: Wed Jul 08, 2009 7:59 pm |
Hi all
Well I have had the engineer in and it appears to be the diverter valve in the boiler, he proved it with a screwdriver, there appears to be a pin that it popping up and down when it shouldn't.
So I am just awaiting a price then we can ponder on either going for the repair or new boiler..
| Top |
register or
log in
thescruff
Posted: Wed Jul 08, 2009 8:05 pm |
| OAP |
Does it pop up and down when other outlets are used.
I still say the problem is the valve, possibly backflow.
| Top |
register or
log in
wickerman999
Posted: Wed Jul 08, 2009 8:18 pm |
Hi
It is really weird it only does it with the shower, I have cleaned the shower out replaced the hose and cartridge and still it does it the only time it didn't is when the engineer proved it with the boiler.
| Top |
register or
log in
