It is currently Mon Jul 16, 2018 7:55 am
 Post subject: shower leak
PostPosted: Sat Jul 08, 2017 2:26 pm
Has thanked: 2 times
Been thanked: 1 times
Hi all.
we've had a shower fitted but have discovered a leak behind a stud wall.
The leak seems to be coming from a misaligned thread (?) nearest to the camera where it goes into the ring.
see attached photo..
Whats the best way of unscrewing this... its stuck fast.
is there a specialist tool for this?
thank you kindly in advance
will
 Post subject: Re: shower leak
PostPosted: Sat Jul 08, 2017 3:49 pm
Been thanked: 6 times
Possibly one these will fit , https://www.amazon.co.uk/Am-tech-C3155- ... 6ECWN2GTCM
PostPosted: Sat Jul 08, 2017 4:03 pm
Has thanked: 44 times
Been thanked: 1292 times
If its cross threaded, make the hole bigger, use a spanner or pump pliers to undo the nut on the copper pipe, then unscrew the screw (probably two, one bottom one top of the flange) take it out, buy a new one and reverse the process.
Since its cross threaded its "banjaxed" so will have to come out, and key hole surgery is a pain, hence make the hole bigger and take it all out.
PostPosted: Sat Jul 08, 2017 7:00 pm
Has thanked: 811 times
Been thanked: 884 times
I have to ask, but why is whoever fitted it not coming back to sort it?
Dave
www.drlgas.co.uk
PostPosted: Sun Jul 09, 2017 9:48 am
thanks everyone.. i tried a radiator hex key as suggested but it didn't fit.
'someone-else' - yep i think that what will have to be done
'gas4you' - the shower was out of operation a long time after the pipework was installed. Our plumber was difficult to get hold of at the best of times and i'd rather not bother to be honest...
Any of you guys in bristol or know a good plumber in the area?
failing that, could it be a job for a novice? (me)
thanks
Will
PostPosted: Sun Jul 09, 2017 9:53 am
ps is anyone able to identify the part names i need. is it the knuckle thing and the thread thing i will need? (pretty sure i haven't used the correct terminology!)
PostPosted: Sun Jul 09, 2017 10:15 am
The wall plate elbow, as an example, plumb center part no 543482 and then the other bit will be a 1/2" 'nipple' of some sort
Dave
www.drlgas.co.uk
