It is currently Thu Sep 20, 2018 8:17 am
 Post subject: Shower diverter problem?
PostPosted: Sun Aug 27, 2017 2:24 pm
Been thanked: 1 times
Hello,
I'm no DIY expert but have been attempting to fix my shower to bath switch. I believe this may be a shower diverter issue but wouldn't mind some advice from someone who actually knows what they are talking about ( unlike me!).
I have this unit in the bathroom (see photo) that is supposed to, when moved up/down, switch between the bath and the shower. However, when moved, the shower remains on permanentlpermanently, and the taps never start.
Do you think I need to replace it? If so I'm a bit confused about what to buy. The flat is 10 years old and I can't see anything that looks similar on any sites I've looked at. Any recommendations/advice greatly appreciated.
Thanks!
PostPosted: Sun Aug 27, 2017 2:38 pm
Has thanked: 45 times
Been thanked: 1334 times
What picture?
See my signature for info on how to post a picture.
PostPosted: Sun Aug 27, 2017 6:35 pm
Sorry, here is the picture.
[img]
[/img]
Many Thanks!
PostPosted: Sun Aug 27, 2017 6:50 pm
Has thanked: 1484 times
Been thanked: 3783 times
Plenty available...
http://www.betterbathrooms.com/taps/mod ... gK1hvD_BwE
I have never used this company though, so can't recommend them.
PostPosted: Sun Aug 27, 2017 7:37 pm
Has thanked: 591 times
Been thanked: 1719 times
The divertor is a simple valve and what normally happens is that limescale jams it up or the spring fails. It is usually very hard to unscrew the parts which probably have corroded together over time. You might be lucky and manage to get the rounded bit above the spout to undo but I doubt it.
It is a fairly straightforward job to replace the unit (wriggle room permitting) and you can get a replacement unit cheap enough. Cheapest I found was this http://www.screwfix.com/p/swirl-contrac ... -tap/61344
Come back if you need guidance on doing it :thumbright:
Painting with BIN
PostPosted: Sun Aug 27, 2017 9:21 pm
Has thanked: 106 times
Been thanked: 455 times
Some lock in the up position and need a quarter turn to release back down.
Cheers,
Darren
PostPosted: Mon Aug 28, 2017 2:04 pm
It is a fairly straightforward job to replace the unit (wriggle room permitting) and you can get a replacement unit cheap enough. Cheapest I found was this http://www.screwfix.com/p/swirl-contract-deck-mounted-metal-head-bath-shower-mixer-tap/61344
Thanks. I might have a crack at changing it then. I have a Screwfix about a minutes walk from where I live so should easy to grab one of those. What tool would I need to purchase to remove the existing unit and fasten the new one?
Thanks to everyone else for the other responses also :thumbright:
Cheers
PostPosted: Mon Aug 28, 2017 2:20 pm
This is a useful tool for that job http://www.screwfix.com/p/adjustable-basin-wrench/14631
Good luck with the job :thumbright:
Painting with BIN
PostPosted: Mon Aug 28, 2017 2:45 pm
Has thanked: 1075 times
Been thanked: 800 times
If you're replacing them, why not fit a thermostatic bath/shower mixer. Cheap as chips here & even cheaper on eBay;
OurTaps - Thermostatic Bath Shower Mixer Taps 057D with 7 Cms Tall Deck-Mounting Legs https://www.amazon.co.uk/dp/B00AVUQJ7M/ ... PzbY4245HH
Time-served Plumber/Heating Engineer & general wind-up merchant.
The Plumbers Anthem
If you have found my help or tips useful please donate here. Thank You;
Gas Safe RGI
Scottish, British & Proud.
I'm not or never claimed to be Chris Williams.
PostPosted: Mon Aug 28, 2017 7:57 pm
Ok, i've used the tool and managed to get the main nuts loose. I'm now at a point where i'm attempting to get the washers off that you can see at the very top in the photo.
[img]
[/img]
I'm still debating whether they are washers or part of the actual old tap unit. I think they must be a washers as I can't budge the unit!
Whilst the wrench was used to get the nuts loose, I think these washers may be too narrow. The space is very limited in there so I don't think i'll be able to get any leverage with a conventional wrench (not that I have one). Any tips on what I can use for this tricky little bit?
Thanks!
PostPosted: Mon Aug 28, 2017 8:13 pm
Yes, they are what secures the unit to the bath. Undo and remove them and the old unit will lift clear to allow this. Put the new unit in and thread those brass washer type nuts back on (they are much better than the plastic ones that will probably have come with the new one) Replace the larger tap connector nuts and test for leaks. It should be okay.
Painting with BIN
PostPosted: Mon Aug 28, 2017 9:24 pm
Cheers. I've managed to get the nearest one off but the far one isn't budging. The tool keeps slipping off as it's so much wider. I'll try again tomorrow.
PostPosted: Mon Aug 28, 2017 11:23 pm
Can you get a spanner on it? A squirt of WD40 might also help. It looks real tight there but persevere, you are nearly there.
Painting with BIN
PostPosted: Sun Sep 10, 2017 2:55 pm
I forgot to say, I managed to get it off with the adjustable wrench in the end. It just took a bit of practice! Thanks everyone.
For this message the author bms9nmh has received gratitude : dewaltdisney
