It is currently Mon Jul 23, 2018 10:40 am
PostPosted: Sat Oct 14, 2017 12:43 pm
Has thanked: 8 times
Been thanked: 6 times
Hello, everyone
I have had a new bathroom suite put in (bath out, shower cubicle in, new toilet, new handbasin) and, everyday since then, I am getting a strong sewers smell emitting from the bathroom. The new bathroom is two weeks old today, Sat.14.Oct.17, and in the last two weeks I have tried flushing with hot water, cold water, bleach solution, vinegar and bicarb. - to flush any possible human debris from the system but all to no avail. I cannot enjoy my new bathroom because of the sewer stench. Recommendations, please, before I ask the fitter to return? Is there anything else I can try? My home is a parkhome so the sewerage set-up is a bit different to normal dwelling. Thanks, everyone, for any useful suggestions.
From a very upset person :(
For this message the author mermaidnwuk has received gratitude : multiman
PostPosted: Sat Oct 14, 2017 1:19 pm
Has thanked: 397 times
Been thanked: 1406 times
If there's no leaks anywhere, then possibly water is being sucked from one of the traps. You could test that by ensuring that the all the traps have water in (fill from a bottle/jug ) and see if smell goes/lessens.
PostPosted: Sat Oct 14, 2017 1:43 pm
Has thanked: 132 times
Been thanked: 146 times
This has happened to us and every few days we run some water in the bath and also the overflow in the basin. As Ayjay said, it's probably a sort of siphon affect where when we flush the loo it sometimes sucks all the water from the bath trap then there is nothing left to stop sewerage smells from coming up.
The basin trap is a bit different where the water can sit in a small void somewhere and just goes off, so we pour some water in the overflow to wash the stale stuff out and leave fresh water in there.
Mike
PostPosted: Sat Oct 14, 2017 2:08 pm
I will try that and come back for more suggestions, if I need to, thanks.
PostPosted: Sat Oct 14, 2017 2:11 pm
Mike
Hi, and thanks for your comment, Mike. Did you ever cure the recurring smell? Or do you need to do the 'pour some water' all the time?
PostPosted: Sat Oct 14, 2017 3:17 pm
Has thanked: 565 times
Been thanked: 1668 times
It sounds like it is drawing the water out of the traps allowing odour to creep out. You need an anti syphon valve that allows air into the pipe run to prevent syphoning. Something like this https://www.screwfix.com/p/mcalpine-ant ... 32mm/37314
Painting with BIN
For this message the author dewaltdisney has received gratitude : multiman
PostPosted: Sat Oct 14, 2017 4:41 pm
Mike
We have to keep doing it as there isn't a definitive solution to the problem :sad:
Mike
PostPosted: Sat Oct 14, 2017 5:56 pm
That looks impressive! Where would it be fitted, please? I am in a parkhome i.e. very shallow underfloor, and would my plumber need to return to fit this? Thanks for your response and recommendation.
PostPosted: Sat Oct 14, 2017 5:58 pm
Mike
Mike
Hello, again
The idea that there might never be a solution to my smelly, new bathroom really does depress me! :(
PostPosted: Sat Oct 14, 2017 6:04 pm
I wouldn't worry about it too much as every bathroom has a different set up and yours may be easily remedied.
Mike
PostPosted: Sat Oct 14, 2017 6:18 pm
Has thanked: 44 times
Been thanked: 1297 times
But if your bathroom is just 2weeks old, why are you looking for a solution? get who ever installed back.
PostPosted: Sat Oct 14, 2017 6:30 pm
There are lots of different types of air admittance valves and it should be very easy for your installer to fix this. They are only a few quid and easy to install. Have you checked underneath you home to see all the main wastes are not leaking?
Painting with BIN
PostPosted: Sun Oct 29, 2017 2:16 pm
Hello, all
Sorry for taking so long to come back but I thought it polite to return and let you know the outcome.
When he returned from his holiday, I rang the bathroom fitter and he came back. I told him I had tried flushing lots of water and a variety of cleaning solutions through the system - all to no avail. He went under my home to check there were no leaks and fitted an extra trap. Problem cured. No more bad smells. I am so happy with my new bathroom, now.
Thank you, again, to all who tried to help me on here. :)
For this message the author mermaidnwuk has received thanks - 3: dewaltdisney, Grumps, wine~o
PostPosted: Sun Oct 29, 2017 6:26 pm
Has thanked: 1452 times
Been thanked: 3725 times
Thanks for coming back with the update :salute:
PostPosted: Mon Oct 30, 2017 11:46 am
You're welcome. I think it's only right that I let everyone that responded know the outcome. Who knows, it might help others.
