Page 1 of 1
[ 4 posts ] |
| Author |
Message |
stevewestern
Posted: Sun Jul 03, 2011 9:41 am |
| Newly registered Member |
Joined: Wed Jun 22, 2011 2:20 pm Posts: 56 Has thanked: 1 times Been thanked: 4 times
OK, so you are about to start tiling and want to fix a baton to tile up from. What do you use as a baton - So often a piece of timber is not straight enough and I have often wondered if there is not something better, like aluminium trim or whatever - something that is actually straight, can be cleaned off and reused easily, and cut to fit. I sort of imagine that there must be some product on the market that has adjustable legs to allow for leveling it up accurately, maybe some sort of suction/sucker that will fix it to any surface and a replaceable straight 'top' that can be cut, cleaned and replaced as needed to allow fir different length runs. Is there such a thing, or do you all just use any old offcut of roofing baton and sort things out as you go along ?
| Top |
Rookery
Posted: Sun Jul 03, 2011 2:55 pm |
| Senior Member |
Joined: Wed Apr 28, 2010 8:11 pm Posts: 101 Has thanked: 0 times Been thanked: 19 times
I generally use the floor as my batten. Having done my setting out, I mark the position of the bottom of the 2nd row of tiles round the room and measure down from that to do my cuts, using spacers and wedges as required.
| Top |
register or
log in
royaloakcarpentry
Posted: Wed Jul 06, 2011 9:48 pm |
| Senior Member |
Joined: Sun Jan 24, 2010 1:48 pm Posts: 4152 Location: Essex Has thanked: 2 times Been thanked: 327 times
I don't use batten either but come up from the floor to my lazer line.
A good option for you instead of batten would be to fix narrow tile cuts to a level line with some rapid set and then start to tile from these. Then when ready, remove tile slithers and work down to the floor.
| Top |
register or
log in
transitboy
Posted: Thu Jul 07, 2011 10:54 pm |
| Senior Member |
Joined: Sat Apr 10, 2010 7:39 pm Posts: 849 Has thanked: 53 times Been thanked: 80 times
saw a tiler using a set of these Rubi Batten stands 300mm llike the one on trade tiler
| Top |
register or
log in
Page 1 of 1
[ 4 posts ] |
