It is currently Wed Jan 17, 2018 1:24 pm
Visit Thermo worx
PostPosted: Sat Aug 12, 2017 3:12 am
Has thanked: 2 times
Been thanked: 2 times
Hi, I recently installed some SELV downlights and for some reason only 1 set of lights (on the 2nd transformer) are working. There are 4 lights in total, 2 on each transformer, connected to a 1-way switch and then back to the board. I'm wondering if there are any common mistakes people can make when installing downlights that may have caused this issue.
A few notes:
All of the LED bulbs are tested and fine
Both transformers are working (I switched them round with the same results)
The wiring from the board to the switch is definitely OK, the problem is occurring somewhere after the switch
First time wiring in downlights and I sort of winged it, however all connections are fine as is polarity
I've provided a horrifically drawn image of the circuit below (CPC left out for clarity):
Summary:
1mm T&E fed from a 5amp breaker in the CU
Line fed into COM at the switch and out through L1
Neutral in a connector block tucked into the back box
CPC in a connector block tucked into the back box
Line, Neutral and CPC coming out of the switch and into a connector block
Line and Neutral coming out the other side of the connector block to feed both transformers
Transformers supplying 2 LEDs each
Only LEDs on transformer 2 illuminating
Thanks.
PostPosted: Sat Aug 12, 2017 6:11 am
Has thanked: 36 times
Been thanked: 1149 times
If you have swapped the "transformers" over and get the same result, and you have tested the LED lamps and they are working, It only leaves one thing. The cable. Either its damaged or you have a bad* connection.
A multi meter would also have been of use.
* Could be a short which is also not good there fore is a bad connection
For this message the author someone-else has received thanks - 2: 20charecters, multiman
PostPosted: Sat Aug 12, 2017 12:29 pm
Thanks for the reply. I'm relatively certain there isn't a short as everything is visible, I'll check resistance with the multimeter and maybe replace the connector blocks with wago connectors and see if they fare any better, otherwise I'm stumped.
Cheers
For this message the author 20charecters has received gratitude : multiman
PostPosted: Sat Aug 12, 2017 1:12 pm
You don't "Have" to use wagos (But they are good) I was wondering if there is a bad connection in your choc bloc.
As you have a multi meter, why not use that to find the problem? (That's what its for)
PostPosted: Sat Aug 12, 2017 7:13 pm
I never had a multimeter on me at the time, but yeah it would have helped. I replaced the connection box (at the transformer) with a wago lighting box which solved the issue, I assume there was a loose connection on their side of the box which I didn't have access too (no triangle screwdriver - or anything that would fit on hand).
Cheers for the help.
PostPosted: Sat Aug 12, 2017 7:42 pm
Has thanked: 15 times
Been thanked: 37 times
Could your password be "snowwhite&7dwarvesparis"?
Eight characters including special symbol, a number and a capital.
PostPosted: Sat Aug 12, 2017 8:34 pm
:scratch:
