It is currently Sat Jun 23, 2018 9:28 am
PostPosted: Mon Feb 25, 2013 10:24 pm
Has thanked: 2 times
hi,
Parents have just had their lounge plastered and have pulled up the old carpet.
I notice there are some large gaps between the skirting boards and floor boards. If I put my hand near these gaps I can feel a draught coming through.
I want to get these gaps sealed , and also seal the gaps between the floorboards.
Would expanding foam around the edges (between floor board and skirting) and some flexible sealant between boards be ok to use?
The other alternative I am thinking is to lay some plywood.
I would like to increase the insulation levels (without ripping out the fllorboards and laying insulation)
Thanks for looking
PostPosted: Mon Feb 25, 2013 10:32 pm
Has thanked: 42 times
Been thanked: 1266 times
Expanding foam has its uses, between skirting board and floorboard is NOT one of them. It needs to be trimmed and painted if it is to last, it also does not have a "stop expanding button"
Sealant between floorboards gaps sounds a good idea, until the floorboards move, then it falls out, might not all do it at the same time but it does do it.
Go for the plywood option.
I believe carpets make good insulation, oh, you have taken the carpet up......
PostPosted: Mon Feb 25, 2013 10:40 pm
is there anything I could lay between the floor boards and plywood to increase insulation?
Havent personally bought plywood in the past....what thickness should I go for?
Also any guesstimate on how much it wolud cost for 25m2?
PostPosted: Tue Feb 26, 2013 1:08 am
Has thanked: 664 times
Been thanked: 741 times
Start from the other end (from the top). How do your parents want the floor finished?
Carpet, laminate or just the wood planks (with ply on top ???).
If carpet, and if they buy a quality carpet and quality underlay, you will not get any draft coming up through the floor boards and you will possibly seal the gaps at the bottom of the skirting boards.
If the above is not good enough, you must still decide how the floor will be finished. Ply will vary in price by its thickness and finish wood. For the bottoms of the skirting boards you could use a thin bead of decorators caulk.
PostPosted: Tue Feb 26, 2013 12:15 pm
Been thanked: 8 times
The easiest and most effective method is to fit beading all around the room to seal the gap
