It is currently Fri May 25, 2012 7:51 pm
PostPosted: Mon Nov 21, 2011 9:46 pm
Has thanked: 8 times
Does any one have any tips for how you form a decent seal between the bottom of a shower enclosure and the shower tray? Is there a particular type of silicon/sealant that is better than others? I can never seem to crack this problem.
PostPosted: Tue Nov 22, 2011 12:36 am
OAP
Has thanked: 187 times
Been thanked: 2115 times
You shouldn't seal the inside bottom edge or the water can get trapped.
A bead along the outer edge is all it needs, and Dow Corning is the best.
PostPosted: Tue Nov 22, 2011 9:53 am
Has thanked: 17 times
Been thanked: 266 times
I would check that there is not movement when someone is on the tray. Any flex will make the joint fail and water will creep through. How is the tray fixed??
PostPosted: Tue Nov 22, 2011 10:26 pm
There's no movement on the tray, its securely in place. So is the idea to have a thin bead along the outer edge?
PostPosted: Tue Nov 22, 2011 10:49 pm
OAP
I always bed the bottom rail then run a bead along the outside and the wall edges inside and out
