It is currently Mon Mar 25, 2019 8:26 pm
PostPosted: Tue May 29, 2018 1:10 am
So i have a wall light that has two lights on it but the thin metal ring that the small bayonet bulb hooks onto is just spinning around in the socket so the bulb doesn't make contact with the pins! (tried bending the metal outward to act as a buffer but the plastic is worn)
I am looking at a lampholder like this one (https://www.amazon.co.uk/gp/product/B00PAWZUR6/ref=ask_ql_qh_dp_hza) but that one doesnt look like it has a neutral terminal on it? so is this the right one and if it is what do i do with the neutral? (the wires to the fitting are brown and blue which, i am assuming is live and neutral although i know that blue could also be a switch wire as there is a wall switch and a pull cord on the light)
this is an example of the light - http://www.sparkydirect.co.uk/product/2960/20878/601-2AN/Endon-Lighting-Recessed-Wall-Mounted-Antique-Brass-Wall-Light-Semi-Flush-SBC-cw-Opal-Glass-wo-Lamp-2x60W-260x200x190mm/index.html
I should probably also point out that we dont use the pull cord on the fitting so if the blue wire is that switch then it doesn't have to work
PostPosted: Tue May 29, 2018 7:57 am
Has thanked: 41 times
Been thanked: 1448 times
The lamp holder you link to on Amazon is a "normal" SBC lamp holder, why do you think it has no neutral?
I should also point out that an SBC lamp holder is for the small lamp fitting and the "usual" fitting is called BC
PostPosted: Tue May 29, 2018 12:15 pm
The one I linked to doesn't say or show that it has a neutral? What do you mean by usual fitting? It's not a big bayonet if that's what your asking? It's a small bayonet!
Sent from my ONEPLUS A3003 using Tapatalk
PostPosted: Tue May 29, 2018 4:27 pm
Why would it show it has a neutral, it doesn't show it has a live either. It has no need to show anything, its a lamp holder.
Just so long as you are aware the one you linked to is small, that's fine. I wouldn't want you to order one only to find out its small, and you want a "normal" size one.
PostPosted: Tue May 29, 2018 6:04 pm
Has thanked: 1535 times
Been thanked: 3869 times
Just replace the light fitting.
PostPosted: Tue May 29, 2018 6:29 pm
It doesn't show it has a live because that's obvious! How else are you supposed to power it? Surely it should show if it has a neutral like it does for the earth?
PostPosted: Tue May 29, 2018 6:31 pm
Wish I could! It's part of a set of four wall light fittings around the room and a chandelier!
PostPosted: Tue May 29, 2018 6:50 pm
No. What would be the point? and if it was to be labelled L & N, what happens if you turn the lamp round 180 degrees?
