Ultimate Handyman Home
Saw blades
Post new topic   Reply to topic   Thank Post    www.ultimatehandyman.co.uk Forum Index -> Tool Talk
smiffy
Member
PostPosted: Fri May 30, 2008 9:05 pm    Post subject: Saw blades Add User to Ignore List Reply with quote
The time has come for me to think about replacing the blades in my mitre saw and table saw. I know that you can get blades that are either negative or positive rake but can someone please explain the difference, and what are the consequences of getting wrong.
Back to top
PostPosted: Fri May 30, 2008 9:34 pm    Post subject: Add User to Ignore List Reply with quote
finer the the teeth[teeth per inch/circumference]smoother cut but slower feed rate
negative rake laminate cutting
triple chip blades laminate cutting
what do you normaly cut with your saws!!!!
Back to top
smiffy
Member
PostPosted: Fri May 30, 2008 9:38 pm    Post subject: Add User to Ignore List Reply with quote
Mostly MDF, Ply and a bit of pine.
Back to top
PostPosted: Fri May 30, 2008 9:42 pm    Post subject: Add User to Ignore List Reply with quote
i go for trend pro blades 80 tooth in my dewalt flip 254mm
and 64 teeth in my slider [8 1/4" 210mm ish]
Back to top
fin
PostPosted: Sat May 31, 2008 6:45 pm    Post subject: Add User to Ignore List Reply with quote
i own a dewalt dw701 mitre saw. they need -5` rake design blades
i bought the machine of a company on ebay and they also sell different blades. some for table saws some for mitre saws etc
http://cgi.ebay.co.uk/DEWALT-DT4320-CIRCULAR-SAW-BLADE-216-X-30-X-48-TOOTH_W0QQitemZ180248699421QQihZ008QQcategoryZ20797QQtcZphotoQQcmdZViewItemQQ_trksidZp1742.m153.l1262
that would fit my machine. there are others available from that ebay shop
Back to top
Hoovie
Devon DIYer
PostPosted: Sat May 31, 2008 8:39 pm    Post subject: Add User to Ignore List Reply with quote
is negative or positive rake something to do with if it cuts on the down or the up?
so you would use a negative rake blade if you wanted to cut laminate without chipping the surface AND the finished surface side is top?
I don't know the answer - just would like to Laughing
Don't forget to vote in the "Member Location" poll in the Lounge Thumbright
Knowledge is Knowing a Tomato is a Fruit, Wisdom is Not putting It in a Fruit Salad
Back to top
Hitch
PostPosted: Sat May 31, 2008 8:51 pm    Post subject: Add User to Ignore List Reply with quote
Negative or positive rake is the rake angle of the teeth, compared to the centreline (on a circ saw)
If you like, its how far forward the teeth point, thats positive rake.
Negative, is leant slightly back. For plastics, aluminium etc. Stops the points of the teeth ripping through too fast
Back to top
Hoovie
Devon DIYer
PostPosted: Sat May 31, 2008 9:33 pm    Post subject: Add User to Ignore List Reply with quote
Cheers Thumbright
Back to top
mannop125
Junior Member
PostPosted: Fri Jun 20, 2008 2:18 pm    Post subject: Add User to Ignore List Reply with quote
The biggest negative of not getting the right blade is you are putting more stress on your saw. Not only will it ruin or hamper your porject, but it can cause more heat build up in the motor. Always match the blade with the project. If you are cutting pine, you can use a steel blade, but a hard wood such as walnut or oak, you can to use a carbon tip blade.
Back to top
Display posts from previous:
Post new topic   Reply to topic    Thank Post    www.ultimatehandyman.co.uk Forum Index -> Tool Talk All times are GMT
Page 1 of 1
