This has been getting worse recently. The toilet doesn't seem to have a stop-valve or if it has it is inaccessible ( i can just see a screw using a mirror) so i will have to turn off main tap and i'm worried that if I mess up/need a part we will be without water.
Questions:-
a) It may just need cleaning but it seems to be a sealed unit
b) How does it undo from inside the cistern?
c) Will any decent Plumber supplies carry Sanindusa?
d) should I get a plumber
Photo attached
How can I check if I need the:-
Sanindusa Float Valve 300mm Bottom Entry
or
Sanindusa Float Valve 340mm Bottom Entry
http://www.cisternfittings.co.uk/sanindusa-72-c.asp product photos
