It is currently Sun Sep 23, 2018 9:30 pm
PostPosted: Fri Jul 21, 2017 11:12 am
Has thanked: 9 times
Been thanked: 3 times
Hi Guys,(its been a while)
I have to rub down part of the ceiling in the kitchen where I filled in a long small crack and don't want the whole kitchen to fill with dust, does anyone have any tips to reduce the amount of dust from sanding down at all please. :help:
PostPosted: Fri Jul 21, 2017 3:11 pm
Has thanked: 842 times
Been thanked: 368 times
Use dust sheets and a small spray bottle filled with water. Spray it in the air every few minutes and that should stop most of the dust from sitting in the air. That should minimise the mess but won't stop it.
If you have a spare set of hands they can hold a hoover wand over where you're sanding.
If money is no object, for this and future mess free sanding buy a Mirka sander
For this message the author Argyll has received gratitude : multiman
PostPosted: Fri Jul 21, 2017 8:50 pm
Has thanked: 716 times
Been thanked: 796 times
This would be about the cheapest dust sheet you can get https://www.toolstation.com/shop/Painti ... eet/p46541
For this message the author OchAye has received gratitude : multiman
PostPosted: Sat Jul 22, 2017 9:02 am
Has thanked: 112 times
Been thanked: 95 times
An alternative might be to rake it all out, then fill again in stages, using a surface filler with a wide scraper or blade to apply it - this should leave you with a surface that needs little or no sanding..
PostPosted: Sat Jul 22, 2017 9:22 am
Has thanked: 592 times
Been thanked: 1720 times
Sander in one hand hoover nozzle in the other works. You may have to lift your vacuum up on a workmate to get the reach.
Painting with BIN
PostPosted: Mon Jul 24, 2017 9:26 am
Thanks for the tips guys, put a dust sheet down in the end but a bit messy still, but all done now (ish)
will post pics tonight when I get home as I am not 100% happy with the finish even though I raked out the crack a bit so to make sure I got enough filler in there and did use a extra wide filler knife it still seems a bit "unpleasant" on the eye and its the first thing I notice when I walk into the kitchen and look up at the ceiling. So might re-do the repair again. :wink:
PostPosted: Mon Jul 24, 2017 7:48 pm
Hi guys how do I attach a photo straight from my iPhone
PostPosted: Mon Jul 24, 2017 8:05 pm
Should I redo the whole thing again?
