It is currently Wed Jan 23, 2019 8:11 pm
 Post subject: sanding plaster
PostPosted: Tue May 15, 2018 5:40 pm
Has thanked: 22 times
hi, could you please advise what grit sand paper to use between mist coats and do you sand second mist coat before top coating ? many thanks
 Post subject: Re: sanding plaster
PostPosted: Tue May 15, 2018 6:25 pm
Has thanked: 1509 times
Been thanked: 3840 times
No need to sand after mist coating... unless you've done it wrong. :shock:
PostPosted: Thu May 17, 2018 3:45 pm
Has thanked: 14 times
Been thanked: 54 times
If you have to and, as wine~o says, shouldn't need to unless you've painted over a problem - maximum 120 grit (preferably 240) and even then you want to be gentle and re-mist any bald patches
There are no problems - only solutions
For this message the author 54aardvark has received gratitude : trevdell
PostPosted: Thu May 17, 2018 7:28 pm
CLOSED ACCOUNT
Has thanked: 900 times
Been thanked: 764 times
Sorry to disagree guys but you should sand your mist coat.
Mist coat - fill - sand has always been the way to go in the decorating game, whether it be with a pole sander, sanding pads or the newer dustless sanders.
I generally sand or at least denib between every coat.
Sent from my SM-G850F using Tapatalk
For this message the author fitzy has received thanks - 2: Have Brush Will Travel, ian gibson
PostPosted: Thu May 17, 2018 7:53 pm
Ahhh I always sand, fill, then mist coat. I've been getting it wrong then :help:
BTW I assumed (perhaps stupidly) that this was new plaster...
PostPosted: Thu May 17, 2018 8:11 pm
CLOSED ACCOUNT
Yeah, mist coat on new plaster. I sand it to completely remove any orange peel effect from the rolled mist coat and to sort out all the filling that's been done. Leaves a far flatter finish once done.
For this message the author fitzy has received gratitude : trevdell
PostPosted: Thu May 17, 2018 9:59 pm
Has thanked: 100 times
Been thanked: 122 times
With Fitzy on this, always sand between coats of emulsion, mist coat included, and never ever sand bare plaster.
For this message the author ian gibson has received gratitude : trevdell
PostPosted: Fri May 18, 2018 8:12 am
Has thanked: 905 times
Been thanked: 477 times
I do a quick sand (feel with my hand for any obvious bits that need sanding) before a mist coat knowing that I will do a more thorough fill and sand after the mist coat as I find the mist coat helps to show up any bits that I might otherwise not see.
For this message the author Tom d'Angler has received gratitude : trevdell
PostPosted: Sun May 27, 2018 7:28 am
many thanks guys will sand de-nib between coats then.
PostPosted: Mon May 28, 2018 9:46 am
Has thanked: 244 times
Been thanked: 247 times
I've had situations where I've had to scrape of a wall because paint has failed over time (adhesion wise) (not mine) and it's cuffed it up a bit so I've always sanded the bare plaster flat. Never had an issue and it's years later.
Plus1 for Fitzys method.
PostPosted: Tue May 29, 2018 9:50 pm
Has thanked: 221 times
Been thanked: 389 times
I ........
Scrape the wall over with a broad knife
Mist coat
Check for filling and fill with easi fil or simlar
Rub down the whole wall
Then 2nd/3rd coat
I dont fill or rub down bare plaster because it will scratch the surface, you can also see more dents etc after the mist coat
