Ultimate Handyman Home
Saggy plasterboard
Post new topic   This topic is locked: you cannot edit posts or make replies.   Thank Post    www.ultimatehandyman.co.uk Forum Index -> Plastering Forum
Mooncat
PostPosted: Sat Jul 19, 2008 9:49 pm    Post subject: Saggy plasterboard Add User to Ignore List Reply with quote
How do you stop plasterboard sagging between joists when using pink skim? Two of my ceilings show this (done by pro plasterers), it's not too bad except if you use a low-profile light fitting.
Back to top
misterk
Junior Member
PostPosted: Sun Jul 20, 2008 10:47 am    Post subject: Add User to Ignore List Reply with quote
Was the correct thickness plasterboard used?
12mm is best on ceilings to prevent sagging.
Back to top
Mooncat
PostPosted: Sun Jul 20, 2008 10:38 pm    Post subject: Add User to Ignore List Reply with quote
I suspect that both ceilings are 9.5mm. I've come to realise that the thicker sheets are worth the small extra money.
Back to top
PostPosted: Mon Jul 21, 2008 5:19 am    Post subject: Add User to Ignore List Reply with quote
I don't think there is anything you can do apart from overboard them with 12mm or rip it down and start again, or you could have it artexed- some patterns might hide it a little.
DIY | DIY Video
Back to top
Hoovie
Devon DIYer
PostPosted: Mon Jul 21, 2008 8:35 am    Post subject: Add User to Ignore List Reply with quote
if you have easy access from above, could you fit noggins at various places between the joints and then screw into those from below to give the extra support?
Not sure if that would end up being more work then is worth it?
If you have a son, DO NOT name him after a verb ....
"Which is it, man?"
Back to top
Mooncat
PostPosted: Mon Jul 21, 2008 8:53 pm    Post subject: Add User to Ignore List Reply with quote
I've decided to take the old plasterboard down (3 sheets) and put on some 12mm stuff. After laying out so much on the bathroom, it seems a shame to spoil it with a patched up repair in a few places. Some of the joists need adjusting anyway, been there nearly 50 years. Is there any real point in fixing polythene sheet first, then poking loads of holes in it with screws.
Back to top
fin
PostPosted: Tue Jul 22, 2008 7:46 pm    Post subject: Add User to Ignore List Reply with quote
u need a vapour barrier in the bathroom really these days for building regs iirc. (sure they made us put one up last time though seems daft when it gets holes pocked in it i agree)
weve never had problems with sagging 9.5mm base boards before either. have you got large centres for the joists or something?
Back to top
nearnwales
Junior Member
PostPosted: Wed Jul 23, 2008 7:54 pm    Post subject: Add User to Ignore List Reply with quote
sounds like they plaster boarded it with the joists and not againts them
Back to top
View user's profile Send private message Yahoo Messenger MSN Messenger
Mooncat
PostPosted: Tue Jul 29, 2008 3:42 pm    Post subject: Add User to Ignore List Reply with quote
Just got back home from the Midlands. The ceiling joists aren't as fair as they could be, makes the ceiling look saggy. Will get on with it this week, when Mrs M allows me the time.
Back to top
Display posts from previous:
Post new topic   This topic is locked: you cannot edit posts or make replies.    Thank Post    www.ultimatehandyman.co.uk Forum Index -> Plastering Forum All times are GMT
Page 1 of 1
