It is currently Fri May 25, 2012 7:27 pm
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 10 posts ]
 Post subject: ryobi 4" belt sander
PostPosted: Fri Dec 03, 2010 8:04 pm
Has thanked: 134 times
Been thanked: 474 times
an amazing machine i paid over £100 for mine
with thanks to weegie :thumbleft:
http://www.tjhughes.co.uk/fcp/product/b ... -Case/5573
but beware its a big beestie twice the size and weight off a 3"belt sander
For this message the author big-all has received thanks - 2: jg, StyXSIS
 Post subject: Re: ryobi 4" belt sander
PostPosted: Fri Dec 03, 2010 10:27 pm
Has thanked: 7 times
Been thanked: 17 times
A few bargains to be had in tj hughes. :thumbright:
It may seem difficult at first! But everything is difficult at first.
For this message the author The Weegie has received gratitude : jg
PostPosted: Tue Dec 07, 2010 6:50 am
Has thanked: 32 times
Been thanked: 83 times
Nice find BA, ive just ordered the ryobi 6 pack & the belt sander for my nephew. & ive ordered the 18v AEG for £80 for myself, that will get my planer going again also. The drill naked is £97 from what i could find so its a big ass bargain all round!.
PostPosted: Tue Dec 07, 2010 8:51 am
just be aware the box is big enough to use as a suitcase :huray:
tool station and its london are where i get my sand paper/discs/belts from but off course shop around :wink:
PostPosted: Tue Dec 07, 2010 5:56 pm
Has thanked: 15 times
Been thanked: 43 times
Is the sanding frame any good?
I've got an old dining table that i've been fixing up, but it has a few marks in the top that I could do with sanding out.
Cheers
J
I am not a pro.
PostPosted: Sun Dec 12, 2010 7:09 pm
sorry missed this answer yes the frame is perfect because its physically impossible to dig the heel in
just be aware any finish will clog the belts up quickly but a wire brush against the rotating belt will clear it
PostPosted: Sun Dec 12, 2010 11:37 pm
Cheers BA,
Got my suitcase the other day, haven't had a chance to try it yet.
I am not a pro.
PostPosted: Mon Dec 13, 2010 12:14 am
some helpful tips with a 4" belt sander
its a very powerful tool if you are using it on any surface where its no attached to a very heavy base then it will need support as in lean against a wall and do random sanding keep the sander moving never going further than around 1or2" sideways over about 2 ft/half length do random distances and widths and turn around and match up the other half this assumes on its own light base or supported on a workmate or bench against a stop or wall
if you have any steps then try and avoid the edge off the belt against the step
if you plan on using on flooring or large stepped area please ask for further guidance
PostPosted: Mon Dec 13, 2010 10:12 am
Many thanks again,
I've not used one before. It's a bit cold in the garage to be trying it out just yet, i'm sure i'll be back on here asking advice when the time comes.
I am not a pro.
PostPosted: Mon Dec 13, 2010 10:54 am
other things to note
it has a soft start so when you pull the trigger nothing happens for about 1/2 a second
always hold onto the sander when plugging in in case its turned on
start the sander before touching the work
if you are sanding on a work bench that is substantial you will need to screw /clamp a batton to hold the work iff you dont the sander will quite happily fire a table top off the bench
you can also use a router mat the best £5 you'll ever spend
http://www.toolstation.com/shop/Hand+To ... /sd/p85326
always sand with the grain or a maximum 5degrees
brace yourself as the sander will pull you over iff your not ready
let the sander do the work its heavy enough
start with course then work down to fine 40 or 60 to 80 or100 then 120 though you can go 60 to 120 no probs
