Inky Pete
Posted: Thu Oct 28, 2010 7:59 pm |
| Senior Member |
Joined: Fri Feb 03, 2006 2:34 pm Posts: 1206 Location: Cheshire Has thanked: 6 times Been thanked: 85 times
It's a very nice price for that lot - especially with 2 batteries.
They must be trying to shift all the NiCad stuff now that the Li-ion stuff is out there.
Pity I can't justify buying one, I've got everything in the kit except the random orbit sander.
Must.....not.....buy.......any........more........Ryobi!
| Top |
register or
log in
Posted: Thu Oct 28, 2010 8:42 pm |
| Site Admin |
Joined: Sat Jul 16, 2005 8:06 pm Posts: 20640 Location: Darwen, Lancashire Has thanked: 127 times Been thanked: 392 times
Inky Pete wrote: It's a very nice price for that lot - especially with 2 batteries.
Must.....not.....buy.......any........more........Ryobi! I bet you could sell your stuff on ebay and buy a full kit with the proceeds. I did that with a load of Dewalt gear of mine
| Top |
register or
log in
diyguys
Posted: Thu Oct 28, 2010 10:27 pm |
| Senior Member |
Joined: Fri Dec 11, 2009 6:32 pm Posts: 1481 Has thanked: 178 times Been thanked: 19 times
ultimatehandyman wrote: Inky Pete wrote: It's a very nice price for that lot - especially with 2 batteries.
Must.....not.....buy.......any........more........Ryobi! I bet you could sell your stuff on ebay and buy a full kit with the proceeds. I did that with a load of Dewalt gear of mine  [/quote That looks a good kit,doesnt mention what the batts are 1.5ah maybe,is it online only.
| Top |
register or
log in
Posted: Thu Oct 28, 2010 10:43 pm |
| Pro Carpenter |
Joined: Sat Dec 16, 2006 10:11 pm Posts: 10527 Location: redhill surrey an auld reekie laddie Has thanked: 134 times Been thanked: 474 times
they will be 1.5 or 1.7 as they dont do the 2.0 now
_________________ we are all ------------------still learning
| Top |
register or
log in
diyguys
Posted: Thu Oct 28, 2010 10:54 pm |
| Senior Member |
The circular saw or jig saw with battery with full charge cutting say 4x2 timber ,how many cuts would you get out of one battery?
| Top |
register or
log in
Posted: Thu Oct 28, 2010 11:00 pm |
| Pro Carpenter |
across or length[??
the 18v chop saw managed 100+ times on 2x1par on a old 1.7ah battery
probably 20 to 40 cuts as a rough geuss but can try tomorow if you like
| Top |
register or
log in
diyguys
Posted: Thu Oct 28, 2010 11:08 pm |
| Senior Member |
Would the jigsaw struggle cutting a letterbox out in a hardwood door,when using the circular saw how many cuts if cutting 8 ft 18mm mdf .
| Top |
register or
log in
Posted: Thu Oct 28, 2010 11:55 pm |
| Pro Carpenter |
mdf i would say 24ft but would probably manage 24ft on 6mm on top as less drag jigsaw will go on for ever as its a low power draw but wouldn't choose to cut any strait lines with it would you like me to try the jigsaw on 3x2"?? one thanks per few threads is enough one per post is great for the ego but not nessesery
| Top |
register or
log in
diyguys
Posted: Fri Oct 29, 2010 12:02 am |
| Senior Member |
So jigsaw no good for letterbox? i see chez done a video using his dewalt batt jigsaw for cutting part of his letterbox.If you have a spare bit of thick timber you could try cutting out a letter box shape for us and let us know the result cheers.
| Top |
register or
log in
Posted: Fri Oct 29, 2010 12:19 am |
| Pro Carpenter |
yes jigsaw can cut letterbox but you need pendulum off 2 hole in diagonal corners[8mm] and cut 3 or 4mm inside the line and finish with a chisel
so you dont want me to try cutting some 3x2 with the circular saw ??? incidentily its a left handed saw but not realy important
| Top |
register or
log in
diyguys
Posted: Fri Oct 29, 2010 1:19 am |
| Senior Member |
No i will take your word on it thanks,why is it left handed ,most people are right handed,so you have to use it with your left hand
| Top |
register or
log in
Posted: Fri Oct 29, 2010 1:39 am |
| Pro Carpenter |
i didn't notice for over 2 years its not left handed as such as it has no extraction there's no hose to get in the way so all you notice when you use it right hand is you see the saw blade rather than the motor and if the off cut is not supported you still have the strait edge on the work to stop accidental wanders into the work but now the saw base is now mostly on the waste side so can dip iff not supported on the last few inches
but as i say i didnt notice for 2 years
| Top |
register or
log in
Posted: Fri Oct 29, 2010 7:55 pm |
| Site Admin |
What is all this left or right handed nonsense. You have two hands so use either
| Top |
register or
log in
diyguys
Posted: Fri Oct 29, 2010 9:17 pm |
| Senior Member |
I wonder if it comes with a storage box.
| Top |
register or
log in
