It is currently Wed Feb 20, 2019 4:02 am
Post new topic Reply to topic  [ 19 posts ]  Go to page Previous  1, 2
PostPosted: Fri Jan 12, 2018 5:37 pm
Has thanked: 10 times
Hi, I picked up some flat twin+ earth 1mm2 cable to wire up the FCU. Is this cable big enough for wiring to the other FCU?
PostPosted: Sat Jan 13, 2018 10:55 pm
Has thanked: 36 times
Been thanked: 109 times
1mm² cable is typically only rated to 6A. *
So if the first FCU is 13A then no.
* subject to many different factors such as method of install, length, whether it's a tuesday, whether the IET have had their bribe from the copper manufacturing industry.... :lol:
Edited to add : When you run cables next to other cables (or anything metal for that matter) for any distance you can induce a voltage on the secondary cable via the wizardry of physics. I'm not convinced the secondary cable having a foil screen in it designed to suppress RF noise and other low voltage data interference is going to help you when you're running it parrallel with a mains voltage conductor.
Last edited by Cantseeitfrommyhouse on Sat Jan 13, 2018 11:00 pm, edited 1 time in total.
PostPosted: Sat Jan 13, 2018 11:00 pm
Taa
PostPosted: Sat Jan 13, 2018 11:31 pm
Has thanked: 40 times
Been thanked: 1429 times
To add to what Cantseeitfrommyhouse said, its also to do with the "what if factor"
If you did use a 1mm cable and put a 5A fuse in line, What if in years to come it was changed to a 13A fuse. The idea of a fuse / protective device is that device should be the weakest link and so should a fault occur it should operate first, so protecting the cable.
In plain English.
Some joker puts a 13A fuse in place of the 5A one, there is a problem, the fuse does not blow, so the next lowest rated thing is the cable, it heats up and starts a fire.
For this message the author someone-else has received gratitude : MattWills12
