-> Carpentry/Joinery Forum |
| Author |
Message |
tawraste Junior Member
Posted: Tue Aug 19, 2008 8:59 pm Post subject: routing a groove on a fire door for an intumescent strip |
hi,
can you help? i'm looking for a router suited to the task of cutting a groove on a fire door edge so that i can fit an intumescent strip.
i have a plunge router, but it is quite large and i have doubts about the safety of using such a large tool on such a small surface area.
any advice, links or ideas would be gratefully appreciated !
many thanks ! |
| Back to top |
Tryanything Senior Member
Posted: Tue Aug 19, 2008 9:50 pm Post subject: |
The router should be ok
The only problem is at the start and finish of the cut
To get over this problem cramp a lengh of timber to the edge of the
door so that it overhangs the ends by 200mm, this will stop the router
from dipping on the start and finish of the cut and also give you a wider
surface for the router to sit on _________________ SILVER---------HOG |
| Back to top |
Posted: Tue Aug 19, 2008 10:07 pm Post subject: ... |
thanks a lot dude,
that's a simple solution, and will save me some bucks.
| Back to top |
jp Junior Member
Posted: Thu Sep 04, 2008 9:26 pm Post subject: |
| sorry to put anyone down, a fire door is not a fire door if it's not done by a certified body. even a simple job as putting in a glass panel. once you tamper with the door it's no longer a fire door. be carefull if you need to certify it for councils of landlords. some companys such as merchants and joiners shops may be certified to do this. |
| Back to top |
lockie Senior Member
Posted: Thu Sep 04, 2008 10:20 pm Post subject: |
| jp wrote: |
So how come i fitted strips to several doors in a very bespoke premise's in london after a visit by the local fire officer ? i also asked their advice on the locks i fitted and followed all their guidelines and they were completely happy with the work carried out ? _________________ london based locksmiths |
| Back to top |
wadge Junior Member
Posted: Fri Sep 26, 2008 9:49 pm Post subject: |
| Also, you can get a router bit that cuts a 'slot' so the base of the router runs on the face of the door rather than on the edge. £40-50 I think. |
| Back to top |
trumpetmonkey Junior Member
Posted: Sat Sep 27, 2008 12:44 pm Post subject: |
| lockie wrote: |
So how come i fitted strips to several doors in a very bespoke premise's in london after a visit by the local fire officer ? i also asked their advice on the locks i fitted and followed all their guidelines and they were completely happy with the work carried out ? |
To be fair to jp, I guess that's his point - that any changes to a fire door need to be certified according to their guidelines. |
| Back to top |
