Ultimate Handyman Home
Rising water pressure
Post new topic   Reply to topic   Thank Post    www.ultimatehandyman.co.uk Forum Index -> Plumbing Forum -> Central Heating & Boilers
gemmybear83
Junior Member
PostPosted: Mon Oct 06, 2008 12:29 pm    Post subject: Rising water pressure Add User to Ignore List Reply with quote
Hi I hope you can help me (I'm new to all of this!)
I have a 9 month year old new worcesterbosch boiler, not had any problems until now...
Started putting the heating on over the last couple of weeks and noticed that the water pressure had gone just over the "2" mark, needed to bleed the radiators upstairs anyway so did, and then repressurised the system to the "1" setting.
Noticed over the last couple of days that after we have had the boiler on it does not got back to "1" instead it seems to linger at "1.5" (this is hours after we have had it on).
Can anyone help?? Any help is much appreciated!
Back to top
thescruff
PostPosted: Mon Oct 06, 2008 1:11 pm    Post subject: Add User to Ignore List Reply with quote
It's normal for the pressure to rise as the heating heats up, how high depends on the volume of the system water, it could be you need an addition expansion vessel.
Set the pressure at 1bar cold, and disconnect the filler loop if, you model has one.
post any results, but remember you are still under warranty, so don't forget the installer.
Scruff
Back to top
gemmybear83
Junior Member
PostPosted: Mon Oct 06, 2008 1:16 pm    Post subject: Add User to Ignore List Reply with quote
Thank you for your response, I only have one cap attached to my filling loop on my model do I just disconnect one end and leave the other end connected, or am I missing a cap??
Thanks again
Back to top
thescruff
PostPosted: Mon Oct 06, 2008 1:22 pm    Post subject: Add User to Ignore List Reply with quote
You don't need to cap the loose hose end.
Can you post a pic of the filler and a model of the boiler just so we're on the same wave length.,
Scruff
Back to top
gemmybear83
Junior Member
PostPosted: Mon Oct 06, 2008 1:57 pm    Post subject: Add User to Ignore List Reply with quote
Thanks the boiler is a greenstar 28i junior - here are the photos.
Back to top
thescruff
PostPosted: Mon Oct 06, 2008 2:09 pm    Post subject: Add User to Ignore List Reply with quote
Carefully disconnect the left hand pipe and cap it off, drain the hose into a bucket.
Scruff
Back to top
gemmybear83
Junior Member
PostPosted: Mon Oct 06, 2008 2:11 pm    Post subject: Add User to Ignore List Reply with quote
Thank you very much - I going to wait until late for someone to come home and give me a hand in case I make a mess will let you know how I get on!
Back to top
Display posts from previous:
Post new topic   Reply to topic    Thank Post    www.ultimatehandyman.co.uk Forum Index -> Plumbing Forum -> Central Heating & Boilers All times are GMT
Page 1 of 1
