It is currently Thu Feb 09, 2012 4:47 pm
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 34 posts ]  Go to page 1, 2, 3  Next
 Post subject: Rexon Tools
PostPosted: Tue Mar 04, 2008 10:09 pm
Thought Rexon should be listed as I sell it...
Only Joking just thought it should be here too
Not because I just sell Rexon I personally think it is good value for money I have had alot of happy customers mainly DIY enthusiasts as this is the market Rexon is aimed at. Although they are up and comming with some great new products
Last edited by Powertoolz.co.uk on Tue Mar 04, 2008 10:15 pm, edited 1 time in total.
 Post subject:
PostPosted: Tue Mar 04, 2008 10:15 pm
Has thanked: 109 times
Been thanked: 406 times
i have played with the extractor you kindly sold me and the suction is unbelivable :thumbright:
when i actualy get round to plumbing it in and trying it i will do a reveiw :hello2:
 Post subject:
PostPosted: Tue Mar 04, 2008 10:17 pm
Great There is no websites with any reviews on Rexon that I have seen so that would be great.
Please also leave a review on our website if you would be so kind
 Post subject:
PostPosted: Tue Mar 04, 2008 10:19 pm
Borders Bodger
Been thanked: 1 times
Hi Nick,
I have a couple of Rexon bench tools and will post reviews of them when I get a chance :thumbright:
 Post subject:
PostPosted: Tue Mar 04, 2008 10:21 pm
Thanks the more reviews the better
Thanks Again
 Post subject:
PostPosted: Tue Mar 04, 2008 10:23 pm
Has thanked: 5 times
Been thanked: 86 times
Didnt you have an issue with your sander Hoovie?
 Post subject:
PostPosted: Tue Mar 04, 2008 10:31 pm
Borders Bodger
I did indeed - though issue may be too strong a word for it.
FYI, powertoolz, I have a Rexon BD150BQ Belt / Disc Sander 230V
and the sanding disc is secured by a grub screw tighted by an allan key and it undid itself - and getting it back in there to retighten was a right PITA - once done, it was fine again .............
except now it came loose again :angryfire: I know now how to retighten and will probably use some of that stuff you put on screws to keep them in place (sliplock? lockthread? copperslip? what is it called :scratch: ) this time round.
Apart from that, I like it a lot :thumbright:
 Post subject:
PostPosted: Tue Mar 04, 2008 10:37 pm
Never heard of this sort of thing. At least it's not so bad they are a good little sander
 Post subject:
Locktite :lol:
 Post subject:
PostPosted: Tue Mar 04, 2008 10:55 pm
Pro Handyman
Has thanked: 18 times
Been thanked: 26 times
Not copper slip, you'll never get it locktite but it'll be a breeze to loosen and tighten and loosen and tighten even in extreme heat :-P
Jaeger.
darrenc wrote:
I dont think its a stupid question but does show a lack of understanding of how paint works and reasons for certain applications, now dont jump down my throat Jaegar i'm not being funny its just a classic case in point of a well educated professionally trained painter against a general tradesman.
 Post subject:
PostPosted: Tue Mar 04, 2008 10:59 pm
Borders Bodger
just googled copperslip - it is for use with cars isn't it :scratch: I think I had a small tube of it from way back when, but couldn't recall why :lol:
So a tiny bad of locktite on the tip of the grub screw (or thread?) will stop this undoing?
 Post subject:
PostPosted: Tue Mar 04, 2008 11:04 pm
Copperslip is essential on stainless nuts and bolts :wink:
 Post subject:
PostPosted: Tue Mar 04, 2008 11:09 pm
Pro Handyman
Copperslip is ideal for stopping brake squeal, slap some on the shimmy things called shims. They sit between the calliper and the pad, copper slip is used as it will withstand the heat when standard grease would just melt and slip or burn off.
Another useless piece of information.
Boy I do worry about myself sometimes and I know I'm not alone in that, which can, in some small ways, be quite comforting.Image
Jaeger.
 Post subject:
Pro Handyman
Is that to stop catalytic effects?
Jaeger.
 Post subject:
PostPosted: Tue Mar 04, 2008 11:22 pm
No, not to stop any bimetalic corrosion, ptfe or epdm washers are normally used for that.
Stainless fasteners cause a lot of friction between themselves, the heat, then makes them bind up on each other. Especially if your using them with impact wrenches etc. They can get so tight the only way is to cut the bolt and replace.
